How can i translate VBA syntax :
currMenuGroup.Menus.item(i).item(j).SubMenu.item(k).Caption
In VLISP
I want to find a submenu in a partial menu like :
TPS
" Test"
"Subtest-versionnumber"
To compare the version number !
Thank you very much for your help
Daniel OLIVES
(french user)
Daniel,
; get root pointer to menus (setq menuGrp (vla-get-menugroups (vlax-get-acad-object))) ; get a pointer to acad.cuix file (setq acadcui (vla-item menuGrp "acad")) ; get the menus (setq menus (vla-get-menus acadcui)) ; get file menu (setq file-menu (vla-item menus "&File")) ; get the first menu item (setq item1 (vla-item file-menu 0)) ; get the second menu item (setq item2 (vla-item file-menu 2)) ....... ....... ; get the fivth menu item (setq item5 (vla-item file-menu 5)) ; get caption (setq caption5 (vla-get-caption item5)) ; return "&Close"
Cheers,
Moshe
Thank you for your help.
I find a direct way without any control !
(setq LabelSubMenu (vlax-get-property (vla-item (vla-get-submenu (vlax-invoke-method (vla-item (vla-get-Menus (vla-item (vla-get-MenuGroups (vlax-get-acad-object) ) 0 ) ) 0 ) 'Item 20 ) ) 0 ) 'label ) )
The menu index for my exemple is "20" and in submenu first so "0" !
I search a best way and post it !
Daniel OLIVES
I use this way to an automatic reload of mpartial menu when I update it.
I control if the labet of version is correct and if not i reload !
It work in VBA, but before migrate to dot net, i convert all in VLISP !
It is a good exercice !
Because i think it is very important to know how do al things in VLISP or LISP in AutoCAD so after it was easy to know how is possible or not !
Daniel OLIVES
