- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have written a couple programs that use the TRIM command and have noticed that it will not trim away the line if I am zoomed out too far. I have set OSMODE to 0 and used "NON" before supplying the point, but it doesn't trim it away. Is there something else related to supplying points to the TRIM command that I am missing?
Specifically, I wrote a program that adds a radius undercut to a corner by drawing a circle with the quadrant at the intersection of the two lines, then trims away the excess of the circle and the line that is being undercut. But, if the undercut radius is really small and I am zoomed out to see the entire part, it will only trim away the excess of the circle and will not trim away the excess of the line, but if I zoom in so that the radius will take up a good portion of the screen, it will work fine.
