Using ActiveX/LISP to get/set plot configuration
Message 1 of 23
Hello ActiveX gurus,
Kind of a tall order this time.
Using ActiveX/LISP, how would I go about getting/setting plot properties? I
figure it's probably something like:
(vla-get-property some_object "PlotHidden") and
(vla-put-property some_object "PlotHidden" vlax:true) or something.
I guess the real questions are what object(s) do I use to get/set the
following plot properties, and how do I get these objects?
1. layout name
2. output device name
3. paper size
4. paper units
5. drawing orientation
6. Plot upside down
7. plot area
8. plot scale
9. plot offset
10. Plot with plot styles
11. plot style table name
12. Plot with lineweights
13. Remove hidden lines
14. Write the plot to a file
15. Save changes to model tab
Thank you much once again,
Eric S. [email protected]
Replies (22)
Message 21 of 23
I examined it very closely and came to that very
conclusion. Hey, don't worry. I don't work for the I.R.S. or anything.
Anyways, thanks for all the help, and never mind about the "B" question
. I understand. It's very private.
Message 22 of 23
Fatherly advice:
A man who has friends should show himself friendly...
Cliff
Jimmy B wrote in message
news:[email protected]...
| Mine isn't.
| Best regards: Jimmy B
| CAD coordinator at Emtunga International AB
| http://hem.fyristorg.com/cadman/
| www.emtunga.com
Message 23 of 23
What ever Jimmys last name is, he's given me good help more than once. So
have you Cliff Middleton. Thanks guys.
