Use user Input as Value?
pmercader
Message 1 of 12
pmercader
Hello guys,
How can I use a string as a way to call for a block name?
What I want is call for command TST
TST asks for a String value and calls it tst1
Steal looks into .dwg and finds a block name with tst1 value
Inserts block with block name tst1 value.
Here is a lisp I have and I dont know how to make it work.
(defun c:TST (/ cde cmd oldlayer pt)
(setq tst1 (getstring "enter test string:"));
(Steal "../path/path1.dwg" '(("Blocks" tst1)));
(setq pt (getpoint "\nSpecify insertion point: "));
(command "-insert" tst1 pt "" "");
Accepted solutions (3)
Replies (11)
Message 2 of 12
SeeMSixty7
Your routine is fine, but you are using a quoted expression which means evaluate this verbatim.
(Steal "../path/path1.dwg" (list (list "Blocks" tst1)));
Remove the quoted string and build the list using the list function I used two lists as your original argument was a list lists.
Good luck
Message 3 of 12
pmercader
Thanks for the response however I am getting this error
Command: TST enter test string:test123
Error: bad argument type: listp "test123"
Message 4 of 12
dlanorh
Try it this way
(defun c:TST (/ tst1 cde cmd oldlayer pt)
  (if (not (tblsearch "block" tst1)) (steal "../path/path1.dwg" (list (list "Blocks" (list tst1)))));
  (command "-insert" tst1 pt);
  (while (= (logand (getvar 'cmdactive) 1) 1)(command ""))
Note the last two lines for inserting a block with "command" and you are never sure how many accept defaults you need.
I am not one of the robots you're looking for
Message 5 of 12
dlanorh
Sorry, amended above as I missed a list out.
Message 6 of 12
pmercader
Thanks you Very much. Works like magic!
Message 7 of 12
pmercader
One additional request, if the lisp couldnt find the string in the .dwg, how can I communicate that as "no block found"?
Message 8 of 12
dlanorh
Which drawing? The one you are running the code in or the remote drawing you are stealing from?
Message 9 of 12
pmercader
If the lisp could not find the block in the remote drawing.
Message 10 of 12
dlanorh
The steal lisp doesn't return anything so you would have to test again, and also ensure that the "insert" code doesn't run as this will error.
Try this. Brief testing, it works on my system.
(defun c:TST (/ tst1 s_path blk_b pt)
        s_path "../path/path1.dwg"
        blk_b T
  );end_setq
  (cond ( (not (tblsearch "block" tst1))
          (steal s_path (list (list "Blocks" (list tst1))))
                  (alert (strcat "Block : " tst1 " not found in " s_path))
                  (setq blk_b nil)
          );end_cond
  );end_cond
  (cond (blk_b
  );end_cond
);end_defun
Message 11 of 12
pmercader
I hope I didnt take too much of your time.
Thanks again, works perfectly.
Message 12 of 12
dlanorh
No problem, glad I could help. 👍
