Style Merge
Style Merge
1wildwes
Message 1 of 16
Style Merge
1wildwes
Is there a way to merge styles without using the Standards? Are there good lisp routines that will do this? I know this is an ancient question.
Replies (15)
Message 2 of 16
RobDraw
I used to have one for merging text styles.
Rob
Message 3 of 16
pendean
Community Legend
Community Legend
Which styles exactly?
Message 4 of 16
ronjonp
Sledgehammer approach to force all objects style to standard.
(defun c:foo (/ a d)
  ;; RJP » 2019-10-02
  (vlax-for l (vla-get-layers (setq d (vla-get-activedocument (vlax-get-acad-object))))
    (cond ((= -1 (vlax-get l 'lock)) (vlax-put l 'lock 0) (setq a (cons l a))))
  (vlax-for b (vla-get-blocks d)
    (vlax-for o	b
      (if (vlax-property-available-p o 'stylename)
	(vl-catch-all-apply 'vla-put-stylename (list o "Standard"))
  (foreach l a (vlax-put l 'lock -1))
  (vla-regen d acallviewports)
  (princ)
(vl-load-com)
Message 5 of 16
1wildwes
I was directed to one on The Swamp. It seems to work but my dwg still needs cleaning. I'm trying to merge unwanted styles to a user style, not Standard. These unwanted styles are in use.
Message 6 of 16
RobDraw
There are several LISP routines out there for merging styles. Which styles would you like to merge?
Rob
Message 7 of 16
cadffm
You can not purge styles in use, that incl. the current style because this style is in use...as the current style.
And there is one special thing, that normal BTN tools not handle:
Merging shouldn't be a problem (have you problems with merging, or just with clean/purging?
You can not clean/purge the first style in your drawing, normally it is the STANDARD style, but everyone is able
to rename style, also 'Standard'.
For example:
Standard is the first and Style1 a second one.
you can not purge the STANDARD style.
I rename 'Standard' to "AAA", rename 'Style1' to 'Standard',
now "AAA" is the first style and you can not this one (because it was and is the first style, just the name changed)
First style in your file is
Command: (cdr(assoc 2 (tblnext "STYLE" T)))
Sebastian
Message 8 of 16
pendean
Community Legend
Community Legend
>>>...but my dwg still needs cleaning...<<<
Then it is time to buy a true purge fix https://www.manusoft.com/software/superpurge.html
Just be careful what you ask for, once those genies come out of that bottle all bests are off 🙂
Message 9 of 16
1wildwes
I'm trying to merge several styles into 1 user style, not Standard. It says these styles are in use but I haven't been able to find them. The only C3D styles in the dwg are standard. I found the attached lisp that almost merged all but there are a couple left.
Message 10 of 16
cadffm
Post your DWG (after MTS), it' easier to see where the style is in use 😉
Sebastian
Message 11 of 16
1wildwes
Here is the dwg with almost everything erased. The styles are still there. The only Styles I'm concerned with are the Simplex-3 and Simplex-4, which I want to merge to Simplex.
Message 12 of 16
cadffm
Never ask for some strange things if the file contains corrupt data 😉
Open the file by RECOVER or just run AUDIT,
then try it again.
Simplex-3/4 are part of corrupt or lost tablestyle fragments.
AUDIT yes
Sebastian
Message 13 of 16
1wildwes
I had already tried that several times and just did it again. I am not getting any error messages. Also tried -wblock for the entire dwg. I'm on C3D 2019. What version are you using? Is there a way to see the table fragments listed in the dwg?
Message 14 of 16
cadffm
Not possible to purge after
audit/yes
Purge All (incl.orphraned data)
Sorry i am away from PC now, and perhaps...
I will check it
later/tomorrow/tgis weekend/no later than Monday.
but i was able to purge both style.
Audit or recovet
Purge.. what i missed?
>" Is there a way to see the table fragments listed in the dwg?"
No.
Sebastian
Message 15 of 16
cadffm
Hi again.
Use
Command -Purge all
or create a new layer for example
-la new 123
then use Purge dialog to purge all
Sebastian
Message 16 of 16
1wildwes
Oh jeez I've just been doing regular purge. So sorry and thanks for the help.
