Use return value of command to fill a title block
Schierz
Schierz
I would like to enter a title block into a drawing. The value of the title block should be determined by my own ARX function (or variable).
How would I do that?
My ARX function returns a string:
Cheers,
Rudiger
rkmcswain
What do you mean by "the value of the title block"?
Do you mean you want to push the string returned by your function into a TEXT or MTEXT object?
Schierz
Yes, I want to push it to an MTEXT object. The idea was, to use a title block to do so, like a system variable, but my own varible or the result of my function, i.e. like the modemacro system variable:
Schierz
I found a solution by myself.
Solution: Use a lisp variable to push the output of an ObjectARX function to a title block.
1. The function `phgetscaltext' returns a string. Push the result of `phgetscaltext'  to a lisp variable, i.e. phscale:
2. By creating an mtext, insert the lisp variable phscale as title block into the mtext:
phscale2.png3. After changing the internal value:
phscale3.pngr
4. I call my function to change the lisp variable phscale and the _regen to update the title block:
