URGENT HELP - RECDIM WITH LAYER INFO
angelteh86
Message 1 of 12
angelteh86
Hi... I really need help... I need someone to help include one more column "Layer" as the 4th column to this RECDIM lisp. I am really no good with this so if there is anyone who can help me I will be so grateful...
Many many thanks
Replies (11)
Message 2 of 12
paullimapa
I actually modified this to include the layer column in 2018 on this post:
Solved: Gather rectangular dimension with layer name - Autodesk Community
But looks like color order has been added since then so now I've updated your revised version to include the Layer column.
Paul Li
IT Specialist
@The Office
Message 3 of 12
angelteh86
Hi I have tried it but the dimensions for lengths of the rectangles are not correct after the layer info is included in the lisp. I have attached a screenshot of said issue.
Message 4 of 12
angelteh86
I have also attached a sample dwg for you...
Message 5 of 12
paullimapa
I've think I've resolved the problem.
After running the updated lisp routine (reuploaded in previous post) the Table with the Layer name vs without should now look like this:
Paul Li
IT Specialist
@The Office
Message 6 of 12
angelteh86
omg... thank you so much... it is working as it should be... 😅 though there is actually one more feature i would like to include... i.e., to have the layer text put in the middle of the rectangles... i have attached both the screenshot as well as the sample dwg... is that even possible? 😅
Message 7 of 12
angelteh86
the nature of my work requires that each member/component of the structure to be labelled for "visibility". doing them one by one is really taking up too much time.
Message 8 of 12
paullimapa
Glad that worked out for you.
To get maximum feedback perhaps you should start a new post with this request on placing the name of the rectangles layer to fit in the middle and rotated
Paul Li
IT Specialist
@The Office
Message 9 of 12
angelteh86
I take on your advice... and many thanks for the previous lisp...
Message 10 of 12
paullimapa
You are welcome..,cheers!!!
Paul Li
IT Specialist
@The Office
Message 11 of 12
Sea-Haven
Something like this.
(defun c:wow ( / obj cen lay )
  (setvar 'textstyle "Standard")
  (setvar 'textsize 2.5)
  (while (setq obj (vlax-ename->vla-object (car (entsel "\nPick rectang object "))))
   (setq cpt (osnap (vlax-curve-getStartPoint obj) "gcen"))
   (setq lay (vlax-get obj 'layer))
   (command "Text" "J" "MC" cpt "" 0.0 lay)
(princ)
 Need to set text size, style and possibly set the variable Angbase or change angle, as well as set a layer for the layer name.
Message 12 of 12
angelteh86
Hi... thanks for the suggestion but I am "coding-illiterate". I only know how to use them but I do not know how to code/write the lisp. I am relying on expert/specialist like your goodself to help me with it... 😭
