Message 1 of 12
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have found someone who is having a look at updating some steel section lisps I used before the Cuix menu system came into being. I have just gone back and have tried to run the lisps, but when I load them, I get an error message:-
(load "Rotang") ; error : syntax error
The lisps run up the the end routine which is the 'Rotang' lisp and then obviously bombs out.
While I can follow how the lisps work, unfortunately I don't have the brain power to sort the problem out.
I have attached the two lisps, although there are others that go through the same end routine, and the mnu file for reference.
Please can someone help.
