Update titleblock lisp issue
blkcar
Message 1 of 10
blkcar
Running into a small issue when using Lee Macks utb.lsp.
Every so often after updating my spreadsheet & running the lisp I get the error "dwgname not found in first column of CSV file." Up until this point the lisp is working fine, drawing names are correct & the dwgname does exist in the csv file.
The only workaround I've found is to completely shut down CAD & the reopen the dwg, upon which the lisp runs correctly again.
Has anyone else experienced this issue at all?
Replies (9)
Message 2 of 10
Sea-Haven
Just a guess if you have ran the program before it's not releasing a variable say the "excel application" when you edit the excel its changing the "application" in some way.
This is some examples in code I use. Its at the end of the code.
(if (not (vlax-object-released-p myRange))(progn(vlax-release-object myRange)(setq myRange nil)))
(if (not (vlax-object-released-p mySheet))(progn(vlax-release-object mySheet)(setq mySheet nil)))
(if (not (vlax-object-released-p myBook))(progn(vlax-release-object myBook)(setq myBook nil)))
(if (not (vlax-object-released-p myXL))(progn(vlax-release-object myXL)(setq myXL nil)))
Message 3 of 10
blkcar
Ok thanks I'll give it a try.
Message 4 of 10
john.uhden
@blkcar
What @Sea-Haven responded shows great wisdom and experience when dealing with Excel.
But why not read the CSV as a text file.  It's much more direct and easier.
John F. Uhden
Message 5 of 10
john.uhden
@Sea-Haven
Alan,
I got your private message and must say that I am excruciatingly impressed with your thorough work.
You're not as dumb as I look afterall.  🙄
Well, except that you wouldn't take my wager re: Ash Barty.
John F. Uhden
Message 6 of 10
blkcar
@john.uhden
I'm not sure why txt isn't used instead of csv. As mentioned previously its not my lisp & I'm no where near good at coding lisps to know. I'm can't figure out how to implement @Sea-Haven solution.
Message 7 of 10
Sea-Haven
Can you post a dwg and excel file ? Thats only way to look at it and try to improve. Had a quick look at UTB.lsp and what I posted was for direct read from excel rather than a CSV.
Message 8 of 10
john.uhden
@blkcar
Actually, a .CSV is an ASCII .TXT file.  It just got its own extension because of its format and so that Excel could recognize it easily.
John F. Uhden
Message 9 of 10
blkcar
@Sea-Haven
The code below is slighty modified to work with the attachments.
I don't know if would make any difference to the csv file but currently this is written via marco from my drawing register. It is regulary overwritten when register is updated.
    ;;-----------------------=={ Update Attributes }==----------------------;;
    ;;  Reads a CSV file containing attribute data, and, should the drawing ;;
    ;;  name of the current drawing appear in the first column of the CSV   ;;
    ;;  Drawing List, the program will proceed to update block attributes.  ;;
    ;;  The attributes updated will be those with tags corresponding to the ;;
    ;;  CSV column headings. These will be updated with values from the     ;;
    ;;  row in which the drawing file is listed.                            ;;
    ;;  Example of CSV format:                                              ;;
    ;;  |    DWG     |  Layout*  |   Block*  |   TAG1   | ... |   TAGN   |  ;;
    ;;  |  Drawing1  |  Layout1  |   Block1  |  Value1  | ... |  ValueN  |  ;;
    ;;  |  Drawing1  |  Layout2  |   Block1  |  Value1  | ... |  ValueN  |  ;;
    ;;  |  Drawing2  |  Layout1  |   Block2  |  Value1  | ... |  ValueN  |  ;;
    ;;  *Layout & Block Name columns are optional.                          ;;
    ;;  Possible Warnings:                                                  ;;
    ;;  -  Without a block filter or block name column the code will        ;;
    ;;     update ALL attributed blocks with tags listed in the CSV         ;;
    ;;     headings.                                                        ;;
    ;;  -  Currently designed to run on startup - add to either             ;;
    ;;     Startup-Suite or ACADDOC.lsp to update blocks when drawing is    ;;
    ;;     opened. To disable code running when loaded, remove (c:utb)      ;;
    ;;     from the bottom of the code.                                     ;;
    ;;  Author:  Lee Mac, Copyright © 2011  -  www.lee-mac.com              ;;
    ;;  Version 1.0    -    2011-01-12                                      ;;
    ;;  - First release.                                                    ;;
    ;;  Version 1.1    -    2011-01-13                                      ;;
    ;;  - Added optional 'Layout' column (next to DWG Column) to allow      ;;
    ;;    multiple titleblocks to be updated with different information     ;;
    ;;    within a single drawing.                                          ;;
    ;;  Version 1.2    -    2011-08-28                                      ;;
    ;;  - Removed case-sensitivity of drawing file column in CSV.           ;;
    ;;  Version 1.3    -    2011-12-27                                      ;;
    ;;  - Revised the code to correctly process CSV files generated using   ;;
    ;;    OpenOffice software.                                              ;;
    ;;  Version 1.4    -    2012-01-16                                      ;;
    ;;  - Updated the 'ReadCSV' local function to correctly read CSV cells  ;;
    ;;    containing commas and quotes.                                     ;;
    ;;  Version 1.5    -    2012-09-19                                      ;;
    ;;  - Updated CSV file parser function to account for the use of        ;;
    ;;    alternative cell delimiter characters in CSV file (such as a      ;;
    ;;    semi-colon).                                                      ;;
    ;;  Version 1.6    -    2013-05-22                                      ;;
    ;;  - Removed the need for file extension in first column of CSV file.  ;;
    ;;  - Updated CSV file parser function to correct bug.                  ;;
    ;;  Version 1.7    -    2014-11-01                                      ;;
    ;;  - Fixed bug causing filenames containing ASCII character 46 (point) ;;
    ;;    to not be found in the first column of the CSV file.              ;;
    ;;  Version 1.8    -    2015-04-13                                      ;;
    ;;  - Added support for duplicate attribute tags.                       ;;
    ;;  - Added support for optional 'Block Name' column in CSV file.       ;;
    ;;  - Added inclusion of anonymous block names to optional block name   ;;
    ;;    filter to enable dynamic block support.                           ;;
    ;;  Version 1.9    -    2016-09-18                                      ;;
    ;;  - Fixed implementation of block filter when processing attributed   ;;
    ;;    dynamic blocks.                                                   ;;
    (defun c:utb
            *error*
            ano
            bln bno
            csv
            ent
            flg fnb:fun
            inc
            lst
            sel str
            tag
            utb:blk utb:csv utb:ftr utb:lay
            val
    ;; Location of CSV Drawing List (set to nil for prompt)                 ;;
    ;; If the CSV file resides in the same directory as the drawing, omit   ;;
    ;; the filepath from the location of the CSV file, and only include     ;;
    ;; the filename, e.g. "myfile.csv"                                      ;;
    ;; If only a filename is specified, AutoCAD will first search the       ;;
    ;; working directory for this file before searching the Support Paths.  ;;
        (setq utb:csv "sample.csv") ;; e.g. (setq utb:csv "C:/myfolder/myfile.csv")
    ;; Block Filter (may use wildcards and may be nil)                      ;;
        (setq utb:ftr nil)  ;; e.g. (setq utb:ftr "*BORDER")
    ;; Layout Column (t or nil)                                             ;;
        (setq utb:lay nil)    ;; set to t if CSV file contains Layout Column
    ;; Block Name Column (t or nil)                                         ;;
        (setq utb:blk nil)  ;; set to t if CSV file contains Block Name Column
        (defun *error* ( msg )
            (LM:endundo (LM:acdoc))
            (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
                (princ (strcat "\nError: " msg))
            (princ)
        (setq fnb:fun
            (lambda ( s )
                (if (wcmatch (strcase s t) "*.dwg,*.dxf,*.dwt,*.dws")
                    (vl-filename-base s) s
        (cond
            (   (not (setq sel (ssget "_X" (vl-list* '(0 . "INSERT") '(66 . 1) (if utb:ftr (list (cons 2 (strcat "`*U*," utb:ftr))))))))
                (princ "\nNo Attributed Blocks found in drawing.")
            (   (and utb:csv (not (setq csv (findfile utb:csv))))
                (princ
                    (strcat
                        "\n"
                        (vl-filename-base utb:csv)
                        (vl-filename-extension utb:csv)
                        " not found."
            (   (and csv (/= ".CSV" (strcase (vl-filename-extension csv))))
                (princ "\nAttribute data file must be in CSV format.")
            (   (not (or csv (setq csv (getfiled "Select CSV File" "" "csv" 16))))
                (princ "\n*Cancel*")
            (   (not (setq lst (mapcar '(lambda ( x ) (cons (strcase (fnb:fun (car x))) (cdr x))) (LM:readcsv csv))))
                (princ
                    (strcat
                        "\nNo data found in "
                        (vl-filename-base csv)
                        ".csv file."
            (   (not
                    (setq tag (mapcar 'strcase (cdar lst))
                          lst (LM:massoc (strcase (fnb:fun (getvar 'dwgname))) lst)
                (princ (strcat "\n" (fnb:fun (getvar 'dwgname)) " not found in first column of CSV file."))
            (   t
                (setq lst (mapcar '(lambda ( x ) (mapcar 'cons tag x)) lst)
                      ano 0
                      bno 0
                (LM:startundo (LM:acdoc))
                (repeat (setq inc (sslength sel))
                    (setq ent (ssname sel (setq inc (1- inc)))
                          bln (strcase (LM:al-effectivename ent))
                          val lst
                          flg nil
                    (if (or (null utb:ftr) (wcmatch bln (strcase utb:ftr)))
                        (progn
                            (if utb:lay
                                (setq val (mapcar '(lambda ( x ) (cons (strcase (cdar x)) (cdr x))) val)
                                      val (LM:massoc (strcase (cdr (assoc 410 (entget ent)))) val)
                            (if utb:blk
                                      val (cdr (assoc bln val))
                                (setq val (car val))
                            (if val
                                (foreach att (vlax-invoke (vlax-ename->vla-object ent) 'getattributes)
                                    (if
                                        (and
                                            (setq str (assoc (strcase (vla-get-tagstring att)) val))
                                            (progn
                                                (setq val (LM:remove1st str val))
                                                (/= (vla-get-textstring att) (cdr str))
                                        (progn
                                            (vla-put-textstring att (cdr str))
                                            (setq flg t
                                                  ano (1+ ano)
                            (if flg (setq bno (1+ bno)))
                (if (zerop ano)
                    (princ "\nAll attributes are up-to-date.")
                    (princ
                        (strcat
                            "\n"           (itoa ano) " attribute" (if (= 1 ano) "" "s")
                            " updated in " (itoa bno) " block"     (if (= 1 bno) "" "s") "."
        (princ)
    ;; Effective Block Name  -  Lee Mac
    ;; ent - [ent] Block Reference entity
    (defun LM:al-effectivename ( ent / blk rep )
        (if (wcmatch (setq blk (cdr (assoc 2 (entget ent)))) "`**")
            (if
                (and
                    (setq rep
                        (cdadr
                            (assoc -3
                                (entget
                                    (cdr
                                        (assoc 330
                                            (entget
                                                (tblobjname "block" blk)
                                   '("AcDbBlockRepBTag")
                    (setq rep (handent (cdr (assoc 1005 rep))))
                (setq blk (cdr (assoc 2 (entget rep))))
        blk
    ;; Read CSV  -  Lee Mac
    ;; Parses a CSV file into a matrix list of cell values.
    ;; csv - [str] filename of CSV file to read
    (defun LM:readcsv ( csv / des lst sep str )
        (if (setq des (open csv "r"))
            (progn
                (setq sep (cond ((vl-registry-read "HKEY_CURRENT_USER\\Control Panel\\International" "sList")) (",")))
                (while (setq str (read-line des))
                    (setq lst (cons (LM:csv->lst str sep 0) lst))
                (close des)
        (reverse lst)
    ;; CSV -> List  -  Lee Mac
    ;; Parses a line from a CSV file into a list of cell values.
    ;; str - [str] string read from CSV file
    ;; sep - [str] CSV separator token
    ;; pos - [int] initial position index (always zero)
    (defun LM:csv->lst ( str sep pos / s )
        (cond
            (   (not (setq pos (vl-string-search sep str pos)))
                (if (wcmatch str "\"*\"")
                    (list (LM:csv-replacequotes (substr str 2 (- (strlen str) 2))))
                    (list str)
            (   (or (wcmatch (setq s (substr str 1 pos)) "\"*[~\"]")
                    (and (wcmatch s "~*[~\"]*") (= 1 (logand 1 pos)))
                (LM:csv->lst str sep (+ pos 2))
            (   (wcmatch s "\"*\"")
                (cons
                    (LM:csv-replacequotes (substr str 2 (- pos 2)))
                    (LM:csv->lst (substr str (+ pos 2)) sep 0)
            (   (cons s (LM:csv->lst (substr str (+ pos 2)) sep 0)))
    (defun LM:csv-replacequotes ( str / pos )
        (setq pos 0)
        (while (setq pos (vl-string-search  "\"\"" str pos))
            (setq str (vl-string-subst "\"" "\"\"" str pos)
                  pos (1+ pos)
        str
    ;; MAssoc  -  Lee Mac
    ;; Returns all associations of a key in an association list
    (defun LM:massoc ( key lst / item )
        (if (setq item (assoc key lst))
            (cons (cdr item) (LM:massoc key (cdr (member item lst))))
    ;; Remove 1st  -  Lee Mac
    ;; Removes the first occurrence of an item from a list
    (defun LM:remove1st ( itm lst / f )
        (setq f equal)
        (vl-remove-if '(lambda ( a ) (if (f a itm) (setq f (lambda ( a b ) nil)))) lst)
    ;; Start Undo  -  Lee Mac
    ;; Opens an Undo Group.
    (defun LM:startundo ( doc )
        (LM:endundo doc)
        (vla-startundomark doc)
    ;; End Undo  -  Lee Mac
    ;; Closes an Undo Group.
    (defun LM:endundo ( doc )
        (while (= 8 (logand 8 (getvar 'undoctl)))
            (vla-endundomark doc)
    ;; Active Document  -  Lee Mac
    ;; Returns the VLA Active Document Object
    (defun LM:acdoc nil
        (eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
        (LM:acdoc)
    (vl-load-com)
    (princ
        (strcat
            "\n:: UpdateTitleblock.lsp | Version 1.9 | \\U+00A9 Lee Mac "
            (menucmd "m=$(edtime,0,yyyy)")
            " www.lee-mac.com ::"
            "\n:: Type \"utb\" to run manually ::\n"
    (princ)
    (c:utb) ;; Remove or comment this line to disable autorun
    ;;                             End of File                              ;;
Message 10 of 10
Sea-Haven
I will try to have a look at it reading direct from excel and can check the 1st entry in the spreadsheet is a dwg name, starting at A2.
