Update menus after updating cuix without menu unload/reload?
Jason.Rugg
Message 1 of 33
Jason.Rugg
We have a custom tab/panel in our ACAD ribbon. We are always updating our custom items, the cuix is in a network location that all users have access to but users can't simply shutdown ACAD and relaunch to get the newest updates. The users or myself have to manually unload/reload the cuix to get the newest updates. Is there a better/more automated way of reloading the cuix? My initial thought was a simple lisp that silently runs menuload but there doesn't appear to be command line options for this.
Any suggestions?
Replies (32)
Message 2 of 33
Jason.Rugg
I did remember that I could set the FILEDIA variable to 0 and that allows a silent MENUUNLOAD and MENULOAD. So I started writing a simple lisp that would set FILEDIA to 0 and then run the menuunload command. I can get our custom menu to unload via command line but not reload because I cant specify the network path to the cuix file, only the cuix filename.
Message 3 of 33
ronjonp
Have you tried deleting the MNR file associated with your CUI?
Message 4 of 33
dgorsman
Menu, or ribbon?  Either way,  you need to be considering the workspace - that's what controls the UI elements the user sees.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 5 of 33
Jason.Rugg
This is a ribbon tab/panel.
Message 6 of 33
Jason.Rugg
So do you have a solution by using workspace?
Message 7 of 33
Jason.Rugg
Can you elaborate on this?
Message 8 of 33
ronjonp
Just a stab in the dark, but way back when I was changing graphics and adding stuff to menus/ribbons I had to delete the compiled MNR ( Menu Resource File ) to see those changes. I'm not sure this is the problem you're having though. My case is a bit different too as the cui file is located on each computer ( we have travelers with laptops )  so I'm not sure where this compiled file is stored since it's usually in the same directory as the CUI. Clear as mud ? 🙂
Message 9 of 33
Jason.Rugg
Thanks for the clarification, I don't think it's useful in my scenario though.
Message 10 of 33
Moshe-A
@Jason.Rugg  hi,
have you tried this?
(command "._cuiload" "YourCuiFile")
moshe
Message 11 of 33
ronjonp
Maybe this code HERE can help you with the load/unload.
Message 12 of 33
Jason.Rugg
@Moshe-A I have tried this but my cuix file is in a network location and from what I can tell there isn't a way to specify that location, only the cuix file name which it does not recognize/find.
Message 13 of 33
ronjonp
I just tested the menuunload/menuload for one of my custom CUI's and this worked passing a path to the load?
(setvar filedia 0)
(command "_.menuunload" "IDT")
(command "_.menuload" (findfile "idt.cuix"))
(setvar filedia 1)
I'd probably use the vla route to do this though for a bit more error trapping and not having to mess with setting variables.
Message 14 of 33
Jason.Rugg
@ronjonp Help me understand why it's not working for me, I am not the best at lisp, obviously... Here is my code, when I run it I get the error too many arguments:
(defun c:MENUFIX ()
(setvar filedia 0)
(command "_.menuunload" "KCI-Client_Print")
(command "_.menuload" (findfile "KCI-Client_Print.cuix"))
(setvar filedia 1)
(princ)
Message 15 of 33
ronjonp
That was my bad .. forgot to quote the 'filedia variable .. try this below:
(defun c:menufix (/ f)
  ;; Check if we can find the CUI .. otherwise you'll need to hardcode the path in
  (if (setq f (findfile "R:\\CAD\\Keys\\Menu\\2019\\KCI-Client_Print.cuix"))
    (progn (setvar 'filedia 0)
	   (command "_.menuunload" (vl-filename-base f))
	   (command "_.menuload" f)
	   (setvar 'filedia 1)
    (print "KCI-Client_Print.cuix not found...")
  (princ)
Message 16 of 33
Jason.Rugg
I think this will eventually get it but I think the network path is going to have to be hard coded, how do I do that? The path is: R:\CAD\Keys\Menu\2019
Message 17 of 33
ronjonp
Code updated above .. in lisp you have to escape the \ with \\ in paths.
Message 18 of 33
Jason.Rugg
Still no dice, it still cant find the file, I even added \\ after 2019 before the filename and it still didn't work.
Message 19 of 33
ronjonp
That is very strange. Are you sure you have the correct path and filename?
Message 20 of 33
Jason.Rugg
Got it. I had to remove the "_" from the \\KCI-Client Print.cuix")) and then on the menuunload I had to add the underscore back and remove the cuix extension.
(if (setq f (findfile "R:\\CAD\\Keys\\Menu\\2019\\KCI-Client Print.cuix"))
(setvar 'filedia 1)
(princ)
