How would you replace "/" with "\"?
Message 1 of 8
How would you replace "/" with "\"? using vl-string-translate.
(vl-string-translate "/" "\" "/zzz")
to return "\zzz"?
Replies (7)
Message 2 of 8
_gile
In LISP, backslalsh is the escape character so you have to double it (have a look at this topic).
(vl-string-translate "/" "\\" "/zzz")
Gilles Chanteau
GileCAD
GitHub
Message 3 of 8
Eventually, I`d like to reach the tab syntax "\t" and run it through lisp. SO I will need the backslash to be one character.
Message 4 of 8
_gile
You cannot use a single backslash, it have to associated with another character as control character ("\n", "\t") or as escape character ("\\", "\"").
It woulb be easier to help you if you provided a relevant example of what you want to achieve.
Gilles Chanteau
GileCAD
GitHub
Message 5 of 8
I`d like to create a piece of Mtext which includes a tab.
(setq str (vl-string-translate "/" "\" "1./tzzz"))
(setpropertyvalue (entlast) "Contents" str "")
Should result: 1. tab zzz
Message 6 of 8
_gile
You can use:
(setq str (vl-string-subst "/t" "\t" "1./tzzz"))
But you should simply do:
(setq str "1.\tzzz")
Gilles Chanteau
GileCAD
GitHub
Message 7 of 8
Thank you Gilles!
I did a minor revision. (setq str (vl-string-translate "/" "\t" str)). It had an extra t there. Now it`s working like a charm! 🙂
Message 8 of 8
_gile
Keep in mind you have to consider "\n", "\t", "\\", "\"" as single characters.
Gilles Chanteau
GileCAD
GitHub
