Update Hyperlink Path in Blocks from XLS
thaydenCJMLL
thaydenCJMLL
I have a task to update hyperlinks in a block definition (DetailBubble).
I'd like a tool to search a drawing and it will reference an XLS file to find the new, correct path to assign to that block insert.
The mapping logic is based on the values of 2 known attributes in that block definition, and when the 2 correct pairs are found, the hyperlink is updated in that block from the spreadsheet.
I know how to do this for standard attributes - but working with hyperlinks paths is new to me.  I found a few ideas online, but one uses a 3rd party VLX  freeware tool from a website that my company has blocked.
Is this possible? I wasn't even able to extract the hyperlink paths using the Data Extraction Wizard...
Sample DWG with 2 blocks and the corresponding sample mapping xls is attached.
I've removed real links from the blocks - and back-filled with dummy links for example.
paullimapa
perhaps the discussion on this post will give you some ideas on how to retrieve and apply hyperlinks?
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lisp-to-grab-text-hyperlink-and-inse...
Paul Li
IT Specialist
@The Office
Moshe-A
@paullimapa ,
thank you Paul 😀
