how to make the autolisp to affect already selected object
holyhexor0o0
holyhexor0o0
Hello everyone, I found this nifty autolisp that can align text to a point from the left/right/middle
however it could not affect already selected objects - meaning the user could only select objects after applying the effect
i actually tried with ssget "P" or "I" or clear previous selection but no luck, thanks in advance
EnM4st3r
ssget is affecting already selected objects. So it should work already.
Tried it for the first function and it worked.
komondormrex
check if variable 'pickfirst' is set to 1. if it is then command should work on preselected objects.
holyhexor0o0
It already is on, but it still doesn't work on preselected 😄
komondormrex
it is command 'undo' that overthrows the preselected set.
replace it with
(vla-startundomark (vla-get-activedocument (vlax-get-acad-object)))
and
(vla-endundomark (vla-get-activedocument (vlax-get-acad-object)))
respectively.
holyhexor0o0
Thank you very much, works like a charm
