Update Dynamic Block. - VLAX-ENAME->VLA-OBJECT not Supported in APS?
davidJKE76
Message 1 of 8
davidJKE76
We have a LISP file that manipulates Dynamic Blocks in our .DWG file.
It works locally but when we try to run it on Autodesk Platform Services (APS) I get the error: no function definition: VLAX-ENAME->VLA-OBJECT
I assume VLAX-ENAME->VLA-OBJECT is not supported in the API
I am looking at other ways to try and change the properties.
If I lIST the properties of the block, the two properties are in the Custom section.
I have tried using CHANGE but it cannot see the properties.
Was wondering if anyone had a bright idea to get this to go?
Replies (7)
Message 2 of 8
norman.yuan
Yes, you are correct: VLAX uses AutoCAD COM API, while the AutoCAD in the Autodesk Platform Services (APS) is AutoCAD core console, which does not support COM API. You would need to create a AutoCAD .NET plugin and upload it to your APS account as an Design Automation Activity. Then you can use this Activity to process your drawing (updating dynamic blocks in the draw, in your case).
Norman Yuan
Drive CAD With Code
Message 3 of 8
davidJKE76
Thanks for the reply Norman. You would think there would be a set of default plugins that would be able to do this. Ill investigate the plugin option further.
Cheers
Message 4 of 8
Sea-Haven
Not sure if this helps but with coreconsole you can load the correct ARX as part of running Corceonsole then it exposes the VL etc Do a Google "load arx coreconsole autocad"
Message 5 of 8
BlackBox_
https://www.theswamp.org/index.php?topic=57471.msg609440#msg609440
"How we think determines what we do, and what we do determines what we get."
Sincpac C3D ~ Autodesk Exchange Apps
Message 6 of 8
Sea-Haven
Thanks @BlackBox_ was trying to find.
Message 7 of 8
cooksterZFRS3
Community Visitor
Community Visitor
Thanks for the reply's team. I went down the 'dll' route and with a little AI assistance created a plugin that does the job. My List runs and the dynamic block  is sorted now. Onwards to the next challenge. Cheers.
Message 8 of 8
davidJKE76
Hi all I tried the dll plugin route and it worked a treat. My dynamic blocks are behaving now in APS.
Thanks to the other posts around ARX. I will have a look at that as well when I get a sec.
Cheers Team
