Update Block Definition without ATTSYNC
Fredrik.Karlsson2VZLJ
Message 1 of 10
I have the need to change the layers of the genometry inside a block definitions in order for the blocks to work with vpFreeze. The provided code works but I have to run ATTSYNC, which I can not do because all, or most, at least in my case, attributes will be returned to the orginal position which creates a way to big of a problem. How can I, if it is even possible, update the Block Definiton via the code so I dont have to use ATTSYNC?
Im using AutoCAD Lt 2024, and the blocks that are subject for this code contains attributes and visiblity states. An example block is providede in the attached dwg file. To clearify I am a noob in terms of AutoLisp but half decent AutoCAD user.
Update 2025-10-30:
Doing the same thing by going into the block editor for each Block Def. and changing the genometry layer works just fine without ATTSYNC
Replies (9)
Message 2 of 10
Moshe-A
@Fredrik.Karlsson2VZLJ  hi,
BATTMAN (or ATTSYNC) command update only the attributes of block (and that's  include attributes position)
where the BEDIT (Block Edit) command, handles the block definition (geometry). inside Block Edit session you can change the attributes but as you exist, the update process (regen) does not touch the attributes only BATTMAN (ATTSYNC) does that.
Moshe
Message 3 of 10
So when the block editor exits it runs regen?
Message 4 of 10
Moshe-A
YES and only the block geometric is update.
this behavior is known in AutoCAD since it's born (previous century around 1982) 😀
and why is that?
in these old days attributes where the only way to store textual data in a drawing to create BOM (Bill of Materials)
(no xdata, no Extended Data no Dictionaries where around) so careless Automatic updating blocks could led to disruption of BOM
so AutoCAD gave us BATTMAN\ATTSYNC command to handle attributes separately and even today these commands
does not touch the attribute value (only the graphics properties e.g position, layer, color, text size, text style and text angle.
Moshe
Message 5 of 10
paullimapa
Perhaps we can all gain some insight from the code in the free open source AttRedef.lsp packaged with AutoCAD since Release 10.
I briefly introduced this in my first Free Samples article here:
AUGIWORLD by AUGI, Inc. - Issuu
Paul Li
IT Specialist
@The Office
Message 6 of 10
I tested doing REGEN and REGENALL manully and also adding  (vla-regen doc acAllViewports) and the end of of the function, that moves the block geomentry to another layer,  but nothing I tried works. I still cant get the block genometry to be frozen when the layer is frozen.
Is it possbile using LISP to redefine the blocks from the tool palette which is the idea anyways?
Message 7 of 10
Moshe-A
@Fredrik.Karlsson2VZLJ ,
@Fredrik.Karlsson2VZLJ wrote:
I tested doing REGEN and REGENALL manully and also adding  (vla-regen doc acAllViewports) and the end of of the function, that moves the block geomentry to another layerbut nothing I tried works. I still cant get the block genometry to be frozen when the layer is frozen.
first you say it works
next it does not
Editing the block with BEDIT than exit using save will drags auto regenerating drawing which update all that block references (but not the attributes)
if in BEDIT you changed an object layer (not attribute) this will reflect after regen. any object on frozen\off layer will be hidden.
does that more clear?
Moshe
Message 8 of 10
What works is that the LISP function moves the geometry to another layer, i.e. MyLayer. When the function is done and when you freeze the layer, in this case MyLayer, the geomentry does not get frozen.
Doing the same thing, on the same block, in the same drawing, manualy, meaning going into the block editor, selecting the geometry and changing its layer, exiting the block editor, and then freezing the layer, in this case MyLayer, freeze the geometry works as intended, meaning the manual way works, the Lisp function does not.
After some more testing it seems to be related to block references meaning blocks with a, as i understand it, hidden name like *U310
Message 9 of 10
truongyen2442y
Observer
Observer
If you're only changing layers of block geometry, just:
Use BEDIT
Change the layer of geometry
Save and exit
No need to run ATTSYNC, and no attribute positions will be disturbed.
We take care of the future best by taking care of the present now. https://www.jewelerstoolsmall.com/
Message 10 of 10
Moshe-A
i think i have it 😀
your problem is with this block reference \ insert, delete it and reinsert
changing a dynamic block after creation some times have problems with the already inserts
Moshe
