Update attributes in title box in several drawings
Hello!
I need help to change one attribute in common in several drawings, without needing to open them. I wonder if is there a quick code to that...
pbejse
You wouldnt happen to be using sheet by any chance?
Anyhoo, that request have been asked before. Are you wanting to change the value regardless of the content?  Or is like a fins and replace thingy?
It is a description, all drawings have layouts with title blocks of the same description. I am thinking about a command that asks for the attribute,and give me the possibility to substitute it by another string, in all the drawings in that folder...
pbejse
You are wanting a program that will search for a specific description value  and substiutute it with a new string value only if its a match OR replace the string value of the descritpion regardless of what it is?
For the former:
FIND and REPLACE : ---> Batch Find & Replace Text by LeeMac
And the other option
Regardless of current value: --> Batch Attribute Editor by LeeMac
HTH
