Updat/Replace a block in group of dwgs in a folder without manually opening
I have to replace/redefine a block that's on a set of drawings in a folder.  I've updated the block from the network, and was hoping I wouldn't have to open each drawing individually to redefine it.  Is there a way of doing this with a lisp routine, or script file, or some other way?  Thank-you.
serag.hassouna
There's another request that differs in the folder/files level, but I guess it's similar in nature with block update/redefinition.
For all files in folder, replace block from a identically named drawing
The only 2 conditions are
  1. Both, the "base drawing" and "target drawing" have similar block definition names, & and the used ones will be taken from the "base drawing".
  2. AutoCAD must be opened
If that's really your case, then I'll consider creating a modified VBA routine for that.
What I have is a block that's inserted on 101 files in a folder.  The original block is a simple symbol and resides in a symbols library on the network.  I've made a change to the block since it was first inserted in the 101 files, so now I need to replace the updated block back into those 101 files.  I don't want to open each file, then perform an insert and "redefine" it 101 times.  I'm hoping I can somehow do this globally with a script or lisp routine?
serag.hassouna
Here's the VBA routine I was speaking about.
Public FSO As New FileSystemObject
'The Fucntion ((ExplodeEX)) is written by Randal Rath
'The Source is from this URL:-
' https://forums.autodesk.com/t5/visual-basic-customization/explode-method-in-vba/m-p/336502#M28390
'This Function is used instead of the "Explode" method, that's because it doesn't work with blocks (undocumented issue)
Public Function ExplodeEX(oBlkRef As AcadBlockReference, _
bKeep As Boolean) As Variant
Dim objEnt As AcadEntity
Dim objMT As AcadMText
Dim objBlk As AcadBlock
Dim objDoc As AcadDocument
Dim objArray() As AcadEntity
Dim objSpace As AcadBlock
Dim intCnt As Integer
Dim varTemp As Variant
Dim varPnt As Variant
Dim dblScale As Double
Dim dblRot As Double
Dim dblMatrix(3, 3) As Double
On Error GoTo Err_Control
'What document is the reference in?
Set objDoc = oBlkRef.Document
'Model space or layout?
Set objSpace = objDoc.ObjectIdToObject(oBlkRef.OwnerID)
Set objBlk = objDoc.Blocks(oBlkRef.name)
varPnt = oBlkRef.InsertionPoint
dblScale = oBlkRef.XScaleFactor
dblRot = oBlkRef.Rotation
'Set the matrix for new objects transform
'*Note:
'This matrix uses only the X scale factor of the
'Block reference, many entities can not be scaled
'Non-uniformly!
dblMatrix(0, 0) = dblScale
dblMatrix(0, 1) = 0
dblMatrix(0, 2) = 0
dblMatrix(0, 3) = varPnt(0)
dblMatrix(1, 0) = 0
dblMatrix(1, 1) = dblScale
dblMatrix(1, 2) = 0
dblMatrix(1, 3) = varPnt(1)
dblMatrix(2, 0) = 0
dblMatrix(2, 1) = 0
dblMatrix(2, 2) = dblScale
dblMatrix(2, 3) = varPnt(2)
dblMatrix(3, 0) = 0
dblMatrix(3, 1) = 0
dblMatrix(3, 2) = 0
dblMatrix(3, 3) = 1
'Get all of the entities in the block
ReDim objArray(objBlk.Count - 1)
For Each objEnt In objBlk
Set objArray(intCnt) = objEnt
intCnt = intCnt + 1
Next objEnt
'Place them into the correct space
varTemp = objDoc.CopyObjects(objArray, objSpace)
'Transform & rotate
For intCnt = LBound(varTemp) To UBound(varTemp)
Set objEnt = varTemp(intCnt)
objEnt.TransformBy dblMatrix
objEnt.Rotate varPnt, dblRot
Next intCnt
'Keep the block reference?
If Not bKeep Then
oBlkRef.Delete
'Return all of the new entities
ExplodeEX = varTemp
'Release memory
Set objDoc = Nothing
Set objBlk = Nothing
Set objSpace = Nothing
Exit_Here:
Exit Function
Err_Control:
MsgBox Err.Description
Resume Exit_Here
End Function
'The Subroutine ((BlockReplace)) is written by Serag Hassouna
'The Commented Codes belong to the unsuccessfull trials, they're left for reference
Sub BlockReplace()
    'Get the Application object
    Dim acad As AcadApplication
    Set acad = GetObject(, "AutoCAD.Application.20")
    'Get the Documents Collection
    Dim docs As AcadDocuments
    Set docs = acad.Documents
    'Get folders' directories
    Dim dir1 As String, dir2 As String
    '<<Replace these directories to the actual ones of folder 1 & folder 2>>
    dir1 = "C:\User\AutoCAD files\folder1" 'folder of the base file
    dir2 = "C:\User\AutoCAD files\folder2" 'folder of the target files
    Dim TrgtFo As Folder, BaseFile As File, TrgtFile As File
    Set TrgtFo = FSO.GetFolder(dir2)
    'Declare needed variables
    Dim BaseFilename As String, BaseFilepath As String, TrgtFilepath As String
    Dim BaseDocument As AcadDocument, TrgtDocument As AcadDocument
    Dim AllBlockRefs As AcadSelectionSet
    Dim gpcode(0) As Integer, datavalue(0) As Variant
    gpcode(0) = 0
    datavalue(0) = "INSERT"
    Dim GroupCode As Variant, dataCode As Variant
    GroupCode = gpcode
    dataCode = datavalue
    'Variables for block references in target drawing
    Dim BlockRef As AcadBlockReference, BRefName As String, BRefInsPnt As Variant
    Dim BCount As Integer
    'Variables for the copied objects to the target drawing
    Dim obj() As Variant
    Dim TrgtObj() As Variant
    Dim ssTrgtObj As AcadSelectionSet, DefInsPnt As String
    'Variables for block definitions
    Dim BDefsStatus() As Variant, BDefStatus(0 To 1) As String, BDefSt As Variant 'is block definition modified?
    Dim BDefsCount As Integer
    'Variables for incrementation
    Dim i As Integer, j As Integer, k As Integer, m As Integer, m2 As Integer
    'Iterate through the base folder, get the other file that's named the same
    'Make a selection set for all block reference objects within the target drawing
    'For every block reference, get its name, insertion point and attributes
    'If the corespondant block definition isn't modified, modify it
    'by
    '  1- insert a block reference in the base drawing onto the corespondant insertion point of the
    '     the block reference with the target drawing.
    '  2- explode the newly inserted block reference in the base drawing.
    '  3- copy the explosion objects to the target drawing.
    '      [an attribute definition was inserted within a block definition in the base
    '      drawing & was successfully copied to the target drawing]
    'Note that modification is done with the "-Block" command
    'Finally, insert the modified block into its original insertion point in the target drawing.
    BaseFilename = "basefile.dwg" '<<rename it to the actual base file name>>
    BaseFilepath = dir1 & "\" & BaseFilename
    For Each TrgtFile In TrgtFo.Files
        TrgtFilename = TrgtFile.name
        If Right(TrgtFilename, 4) = ".dwg" Then
        TrgtFilepath = dir2 & "\" & TrgtFilename
        Set BaseDocument = docs.Open(BaseFilepath)
        On Error GoTo NoMatchFile:
        Set TrgtDocument = docs.Open(TrgtFilepath)
        TrgtDocument.Activate
        TrgtDocument.SendCommand "(vl-load-com)" & vbCr 'Prepare for blocks redefinition
        Set AllBlockRefs = TrgtDocument.SelectionSets.Add("allblockrefs")
        Set ssTrgtObj = TrgtDocument.SelectionSets.Add("Block2Define")
        AllBlockRefs.Select acSelectionSetAll, , , GroupCode, dataCode
        BCount = AllBlockRefs.Count
        BDefsCount = BaseDocument.Blocks.Count
        ReDim obj(0 To (BCount - 1)) As Variant 'Base objects to be copied, As Object with CopyObjects method
        'As AcadEntity with Wblock when they're single Blocks
        ReDim TrgtObj(0 To (BCount - 1)) As Variant
        ReDim idpairs(0 To (BCount - 1)) As Variant
        Dim TrgtObjs() As AcadEntity 'for "Block2Define" Selection Set
        ReDim BDefsStatus(0 To BDefsCount) As Variant
        On Error Resume Next 'Make the useless "Invalid procedure call or argument" error go away
        For m = 0 To BDefsCount
            BDefStatus(0) = BaseDocument.Blocks.Item(m).name
            BDefStatus(1) = "Not Modified"
            BDefsStatus(m) = BDefStatus
        Next m
        'Define vlaSel->Sel (docks elements in an ActiveX sset to a new ordinary sset)
        'vlaSel-> is written by Doaiena
        'The replay URL that contains it is:-
        ' https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/convert-selection-set-s-vla-object-to-ordinary-selection-set/m-p/8216368#M373026
            TrgtDocument.SendCommand "(defun vlaSel->Sel ( vlaSel / sel )" & vbLf & _
            "(setq sel (ssadd))" & vbLf & _
            "(vlax-for obj vlaSel" & vbLf & _
            "(ssadd (vlax-vla-object->ename obj) sel)" & vbLf & _
            ")" & vbLf & _
            "sel" & vbLf & _
            ")" & vbCr
        'For every target blockref, insert a similar-named block within the base drawing
        For i = 0 To (BCount - 1)
            Set BlockRef = AllBlockRefs.Item(i)
            BRefName = BlockRef.name
            BRefInsPnt = BlockRef.InsertionPoint
            DefInsPnt = BRefInsPnt(0) & "," & BRefInsPnt(1) & "," & BRefInsPnt(2)
            'get the block definition modification status
                If BRefName = BDefsStatus(m)(0) Then
                    BDefSt = BDefsStatus(m)(1)
                    m2 = m
            Next m
            'if the block definition isn't modified, modify it and change its modification status
            If BDefSt = "Not Modified" Then
                BDefsStatus(m2)(1) = "Modified"
                obj(i) = ExplodeEX(BaseDocument.ModelSpace.InsertBlock(BRefInsPnt, BRefName, 1, 1, 1, 0), False) 'Thanks Randal Rath
                ' "Set" keyword was used with obj(i) when its data type was Object & AcadEntity
                TrgtObj(i) = BaseDocument.CopyObjects(obj(i), TrgtDocument.ModelSpace, idpairs(i)) 'Works with ModelSpace, not with any block definition
                ReDim TrgtObjs(LBound(TrgtObj(i)) To UBound(TrgtObj(i)))
                For k = LBound(TrgtObj(i)) To UBound(TrgtObj(i))
                    Set TrgtObjs(k) = TrgtObj(i)(k)
                Next k
                ssTrgtObj.AddItems TrgtObjs
                'MsgBox ssTrgtObj.Count 'Selection Set works fine
                'Delete the objects resulted from the explosion process
                For j = LBound(obj(i)) To UBound(obj(i))
                    obj(i)(j).Delete
                Next j
                'Redefine block
                TrgtDocument.SendCommand "-Block" & vbCr & BRefName & vbCr & "y" & vbCr & DefInsPnt & vbCr & _
                "(vlaSel->Sel (vla-item (vla-get-selectionsets (vla-get-activedocument (vlax-get-acad-object))) ""Block2Define""))" _
                & vbCr & vbCr
            'MsgBox CStr(idpairs(i)) 'debug line
            TrgtDocument.ModelSpace.InsertBlock BRefInsPnt, BRefName, 1, 1, 1, 0
            ssTrgtObj.Clear
        Next i
        'Delete blocks from target drawings [not used when incrementing with "Item" method to avoid
        'any indexing issues that could result from deletion]
        Dim elem As Variant 'any other data type declaration generates an error
        For Each elem In AllBlockRefs
            elem.Delete
        Next elem
        BaseDocument.Close False
        TrgtDocument.Close True
        End If 'for dealing only with .dwg files
    Next TrgtFile
NoMatchFile:
  If Err.Number = -2145320924 Then
      MsgBox "Base file " & BaseFilename & " has no target one." & vbLf & "Operation Terminated."
  Exit Sub
End Sub
To make it work:
  1. The directory paths must be modified to your working paths.
    you can find and replace them here
    and here
  2. Make sure these reference files are added, you can do that at the visual basic editor from Tools>References
serag.hassouna
Does every symbol reside in a separate .dwg file in the symbols library in the network ?
If that's the case then I guess this file needs to be downloaded first on your local device file system & moved (if needed) to your folder of choice, That's to be able to fetch it with the "Filesystemobject" (That FSO in the included VBA code) from the reference called "Microsoft Scripting Runtime", which is responsible for the iteration through the destination folder.
________
Another wild guess says that you can simply assign the symbol .dwg file's URL directly to the variable dir1, while removing only the last part that contains its name (e.g. "basefile.dwg")
For example, If your base file resides in the url (( http://www.mycompanysite.com/cadfiles/symbolslib/diamond.dwg )) and your folder is ((C:\User\productionfiles\cadfiles))
Then the replaced parts will be like that
    dir1 = "http://www.mycompanysite.com/cadfiles/symbolslib" 'folder of the base file
    dir2 = "C:\User\productionfiles\cadfiles" 'folder of the target files
    BaseFilename = "diamond.dwg "
and the line
would be replaced by
        TrgtFilepath = dir2 & "/" & TrgtFilename
