Unlock all layer via browse folder file
Hello
Can someone tell me code Unlock all layer via browse folder file.
rkmcswain
Are you asking how to unlock all layers in multiple drawing files?
Please clarify. Thanks.
R.K. McSwain     | CADpanacea | on twitter
Yep unlock all layers in multiple drawing file via browse folder.
sanganaksakha
You will have to write a batch program. There are many ways to do that. I think VBA would be easier although Vlisp also could do that.
Basically, you write a code to unlock all layers in a drawing and then in the main program, open each drawing. load and run the program.
- Sanjay Kulkarni<http://www.linkedin.com/in/sanjaykulkarnipune?
patrick_35
Hi
Adapted from one of my lisp
;;; LAY.LSP V1.00
;;; Déverrouiller tous les calques de tous les dessins d'un répertoire
;;; Copyright (C) Patrick_35
(defun c:lay(/ 	att ava bl dbx express fic lay lst obj rep  s tot ver
		*errlay* msgbox dirbox ouvrir_dessin_dbx)
  ;;; Gestion des erreurs
  (defun *errlay* (msg)
    (or (member (strcase msg) '("FUNCTION CANCELLED" ""QUIT / EXIT ABORT"" "FONCTION ANNULEE" "QUITTER / SORTIR ABANDON"))
      (princ (strcat "\nErreur : " msg))
    (vla-endundomark doc)
    (setq *error* s)
    (princ)
  ;;; Message
  (defun msgbox (Titre Bouttons Message / Reponse WshShell)
    (setq WshShell (vlax-create-object "WScript.Shell"))
    (setq Reponse  (vlax-invoke WshShell 'Popup Message 0 Titre (itoa Bouttons)))
    (vlax-release-object WshShell)
    Reponse
  ;;; Choix du répertoire
  (defun dirbox(/ bas cdl rep)
    (if (setq cdl (vlax-create-object "Shell.Application"))
      (progn
	(and (setq rep (vlax-invoke cdl 'browseforfolder 0 "Choose a directory to process all the drawings and unlock all layers" 512 ""))
	     (setq rep (vlax-get-property (vlax-get-property rep 'self) 'path))
	(vlax-release-object cdl)
    rep
  ;;; Ouvrir un dessin via ObjectDbx
  (defun Ouvrir_dessin_dbx(dwg / dbx doc lan rel)
    (and (setq dwg (findfile dwg))
      (progn
	(vlax-for doc (vla-get-documents (vlax-get-acad-object))
	  (and (eq (strcase (vla-get-fullname doc)) (strcase dwg))
	    (setq dbx doc lan T)
	(and (not dbx)
	  (setq dbx (vlax-create-object (if (< (setq rel (atoi (getvar "ACADVER"))) 16)
					  "ObjectDBX.AxDbDocument"
					  (strcat "ObjectDBX.AxDbDocument." (itoa rel))
	  (vla-open dbx dwg)
    (list dbx lan)
  ;;; Routine principale
  (vl-load-com)
  (setq s *error*
	*error* *errlay*
  (if (eval 'acet-ui-progress-done)
    (setq express T)
  (if (setq rep (dirbox))
    (if (setq lst (vl-directory-files rep "*.dwg" 1))
      (foreach fic lst
	(if (setq dbx (ouvrir_dessin_dbx (strcat rep "/" fic)))
	  (progn
	    (setq tot (vla-get-count (vla-get-layers (car dbx)))
		  ava 0
	    (and express
	      (acet-ui-progress-init "" tot)
	    (princ (strcat "\n Work in " fic))(princ)
	    (vlax-for lay (vla-get-layers (car dbx))
	      (and (eq (vla-get-lock lay) :vlax-true)
		(vla-put-lock lay :vlax-false)
	      (and express
		(setq ava (1+ ava))
		(acet-ui-progress-safe ava)
	    (and express
	      (acet-ui-progress-done)
	    (or (cadr dbx)
	      (progn
		(princ " ...Save")(princ)
		(vla-saveas (car dbx) (strcat rep "/" fic))
		(vlax-release-object (car dbx))
	    (princ " ...OK")(princ)
	  (princ (strcat "\n Unable to read file " fic))
      (msgbox "LAY" 64 (strcat "No drawing in " rep))
  (setq *error* s)
  (princ)
