Aplly copy setting to all drawing in browse folder ?
I search code
(vl-load-com)
(defun c:CPS (/ Adoc Layts clyt)
(setq aDoc (vla-get-activedocument (vlax-get-acad-object))
Layts (vla-get-layouts aDoc)
clyt (vla-get-activelayout aDoc)
(foreach
itm
(vl-remove (vla-get-name clyt) (layoutlist))
(vla-copyfrom (vla-item Layts itm) clyt)
(princ)
How can i aplly to multi drawing. Can someone show me code.?
Thanks.
JustoAg
I couldn't run your code because it fails at the vla-CopyFrom function with an "Automation Error. Invalid object type" msg supposedly because you're passing in a Layout Object instead of a PlotConfiguration Object as the source object according to the Reference guide.
Any way, the quick & easy method to apply a routine to all dwg in a folder is to use a Script in the form of
.OPEN C:\folder\AG01E_60.dwg (DoSomeJob) .CLOSE Y
Or similar.
You can make a list from all the dwg in a folder using the DIR *.dwg /b >list.txt, this will create a file which you can modify to want you want and save as .SCR file.
Hope this helps.
Justo Aguiar.
