undo Mark and Back not working.!
tanvikarekar22
tanvikarekar22
I am generating multiple drawings using while loop in autolisp. I want to generate drawing , save it with different name and undo everything then again add next drawing and save it. But there is problem while undo everything in drawing. I used (command "_.UNDO" "_Mark") and (command "_.UNDO" "_Back") commands to undo upto undomark but it is not working. I am attaching my lisp file here. Is there any solution to resolve my problem?
Kent1Cooper
Could it be simply that those commands are commented out in your code?
;(command "UNDO" "Mark")
(setq DrawingName (GetCell (strcat "B" NewCount)))
(setq SrNo (GetCell (strcat "A" NewCount)))
(setq Point (GetCell (strcat "D" NewCount)))
(create_drawing Point SrNo NewCount)
(saveFile DrawingName)
;(command "_.UNDO" "_Back")
If that was just because they weren't working, then I don't see anything else obvious [EDIT:] unless you're using a non-English version of AutoCAD, since the underscore prefix isn't included in the Undo Mark step.
I have used those successfully in an AutoLisp command, namely ReverseDirection.lsp, >here<, so I don't think it's a problem with the command itself or those options.  I don't know whether studying the way they're used there will help you, but you can look.  It's different in calling for Undo Back only if the User asks for it, so its usage may not be really applicable in your situation.
Further EDIT:  What about instead using Undo BEgin and Undo End as the wrapper, followed by (command "_.u") ?
Kent Cooper, AIA
mithmodern26
Community Visitor
Community Visitor
thanks of knowlege for ur commond
tanvikarekar22
tanvikarekar22
No, it's not because I comment it. It's not working properly so just run other program I comment down undoMark and undoBack command. I had also tried using (command "_.UNDO" "_Mark") instead of (command "UNDO" "Mark") but it still not working
Updated code be like-
Also I used undoBegin and undoEnd instead of mark and back, But it didn't undo whole drawing
Kent1Cooper
Here's a crazy idea [which I will leave it to you to experiment with]....
Help for UNDO says it "Reverses the effect of commands."  Could it be that it needs some actual command(s) in between the Undo Mark and Back commands, to give it something to work with other than AutoLisp functions?
Does it work if you do something like this?
(command "_.undo" "_mark" "_.zoom" "0.99x")
.... do your stuff ....
(command "_.zoom" "_previous" "_.undo" "_back")
Kent Cooper, AIA
Scottu2
Look in to the saveFile routine.
Does it perform a saveas or wblock?
