Unable to load commands based in DLL
I am facing issue with AutoCAD customization. I was using older version of AutoCAD along with user based customization (Some dll files), & now have migrated to newer version AutoCAD 2022.
While all the customization has been migrated and works well I came across an issue today wherein few commands are not seen in newer version. This command were running well in older version.
I found out that this specific commands are user defined commands which is included in some DLL file by earlier users/admins. Upon investigation I saw in my PC's Appdata folder (Roaming), the dll files were present in support folder of older version of AutoCAD but not present in support folder of newer version. I added these dll files manually in support folder of newer version but still was unable to solve.
Do I need to look somewhere else as well? (Beyond C:\Users\AppData\Roaming\Autodesk\AutoCAD 2022\R24.1\enu\support).
I will appreciate if someone can enlighten me.
