Select all Blocks rotated 180 degrees, Isolate them, then rotate all by 180 degrees at their insertion point
johnlagasse
Message 1 of 10
johnlagasse
I have a client that created racks and inserted them at 0 and 180 degrees. I'm trying to rotate the 180 degree racks back to 0. I have another app that is replacing the racks and when they are at 180 they don't land where they are supposed to.  Thanks!
Replies (9)
Message 2 of 10
ВeekeeCZ
(defun c:RotateB180 ( / s i)
  (if (setq s (ssget (list '(0 . "INSERT") (cons 50 pi))))
    (repeat (setq i (sslength s))
      (setpropertyvalue (ssname s (setq i (1- i))) "Rotation" 0.)))
  (princ)
Message 3 of 10
johnlagasse
I have a thousand or so blocks where some are inserted at 0 and some are 180. I want to select all the blocks but only have the blocks that are rotated 180 degrees to be in the selection set. Then I want to isolate them so I know which are at 180, then rotate them by 180 degrees.
Message 4 of 10
ВeekeeCZ
Are you sure you are in the right place?
Message 5 of 10
ВeekeeCZ
The code I've posted selects all blocks with the "Rotation" property of 180°(pi radians in fact) and sets the rotation to 0.
Message 6 of 10
johnlagasse
Wouldn't this be where I'd ask for LISP help.  The rotate 180 LISP you created works great. Just wondering how to select blocks based on their rotation angle. I'm just getting back into the LISP world and not sure how to write a LISP that will do that. I'm very rusty. 🙂
Message 7 of 10
johnlagasse
Sorry I was using it wrong.  Works great!  Thanks
Message 8 of 10
calderg1000
Regards @johnlagasse
Try this code
;;;Rotate blocks to 0 degree angle
(defun c:rtb (/ s i)
  (setq s (ssget (list '(0 . "insert") (cons 50 pi))))
    (setq sn (entget (ssname s (setq i (1- i)))))
    (entmod (subst (cons 50 0) (assoc 50 sn) sn))
;;;It only selects blocks rotated 180 degrees.
(defun c:stb (/ s i)
  (sssetfirst nil s)
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
Message 9 of 10
johnlagasse
That works perfectly.  I can isolate the racks rotate 180 and manipulate only them. Since rotating them places them in a different position I can select similar and move each type of rack back into position.  THANKS!
Message 10 of 10
calderg1000
Glad to help, cheers
Carlos Calderon G
