Unable to copy and paste codes to the command line
gustavobernardi
gustavobernardi
I don't know what variable I may changed, but actually my AutoCAD is not aceppting copy and paste of autolisp codes directly on the command line.
Being more specific, the problem only occurs if the code have more than 24 lines.
I am using AutoCAD 2019.
TIA
andkal
reply deleted
• www.autolisps.blogspot.com - Productivity plugins for Autocad and Autocad MEP
• Autodesk AppStore
CodeDing
@gustavobernardi ,
Can you explain further? How do you know it's not accepting more than 24 lines? Is that all your command history shows? does a message popup? Do you get an error? How are you determining this. It may help us troubleshoot with you.
Best,
~DD
gustavobernardi
Thanks for answering.
I knew because I tried with a few lines and it does work and with a a lot of lines it does not work. That is not what my prompt shows (typing F2, I can see more lines than 24). When it fails, nothing appears on the screen.
Funny thing, I had tried copying to another text file after copying to the prompt line and it works.
Check this out on the video.
CodeDing
Thank you for the video, very useful.
Just curious, have you tried pasting 25 lines without that very-long-named command?
(converterparametrosquadradosporfavor)
