tutorial for controlling The "Custom" parameters of a dynamic block?
acadadmin3KNUF
acadadmin3KNUF
Can someone point me to a tutorial on controlling the "Custom" parameters area in the Properties tab of a dynamic block?  I have over a dozen parameters based on Lookups that I can't re-order inside the block editor...so I'm thinking maybe a custom dialog box programmed with LISP?  I've found some resources on making the dialog boxes, etc., but now I need to know how to access those Custom parameters in the dialog box.   Here's a pic of what I'm trying to reorder:
Thanks for any help!
pbejse
@acadadmin3KNUF wrote:
..., but now I need to know how to access those Custom parameters in the dialog box.
To access custom properties thru lisp look here -> Dynamic Block Functions | Lee Mac Programming
To re-order Custom parameters
  • Launch the dynamic block editor (BEDIT) and open the requested block.
  • Click on the icon "Parameters Manager" (fx) on the Manage tab in the "Block Editor" ribbon (or type the command PARAMETERS).
  • This will open the palette PARAMETERS MANAGER
  • In the palette, display the column Order  - it may be hidden on the right. If it is not displayed, right-click on the heading bar and enable it by checking it. In the dafault state, the Order column is empty
HTH
matthew_neesley
NO!  That does NOT work!  Lookup Parameters do NOT show up in the Parameters window!
CodeDing
@acadadmin3KNUF ,
To access lookup parameters, you will need to look DEEP into the depths of the block record.
Luckily for us, Andrey Lazebny (RIP), performed a lot of this leg work for us.
Check out this page on his work:
http://poleshchuk.spb.ru//cad/2009/tainypod08e.htm
Read the page and the last grouping of green text will show you the path to access the (0 . "ACAD_EVALUATION_GRAPH")... and thence the parameters within your block..
From there I would assume it's feasible to gather the entity names of your parameters, and the string names of them also. Then you could probably create a GUI and utilize entmod to rearrange them... Probably... Idk... Hopefully though. It's a lot of leg work but I would be excited to see your solution.
Best,
~DD
Sea-Haven
I have used lee-mac dynamic block lisp and my own library DCL to display Dynamic block choices for visibility rather than clicking on the block as part of a insertion. There is "BLOCKVISIBILITYPARAMETER" there may be others like "lookup" so can display in a dcl a reorder may then be possible I can see trying to re-order by playing with entmod etc may be difficult. So post a sample dwg and will have  a look.
matthew_neesley
ACTUALLY...I just figured out how it would be possible to totally "go around" the LookUp Parameters.  I will post a follow-up the next 24 hrs 😁
