Trying to remove support paths
chris.neelin
chris.neelin
Still a rookie but I'm getting there !!
I have the routine below that sets 2 paths for Tool Palettes, this one sets the path for the electrical group. Because there are multiple disciplines, before this runs, I would like to delete all the paths in the toolPalettePath .
Greatly appreciate any ideas.
(defun prog_main ( / )
;Get environment variable USERPROFILE
(setq IESCAD2016 (strcat (getenv "USERPROFILE") "\\IESCAD2016"))
(setq ELECTRICCAL (strcat IESCAD2016 "\\EL\\EL_Tool_Palette")) ; set the discipline's path
(setq COM (strcat IESCAD2016 "\\Common_Tool_Palette")) ; set the path for the common tools
; Get the current file preferences
(setq pFiles (vla-get-files (vla-get-preferences (vlax-get-acad-object))))
; Get current tool palette path
(setq thePath (vla-get-toolPalettePath pFiles))
; add paths
(setq thePath (strcat ELECTRICAL ";" COM ";" thePath))
; update support path variable
(vla-put-toolPalettePath pFiles thePath)
(prog_main)
SeeMSixty7
It looks like you can blank it out using
(vla-put-toolpalettepath pfiles "")
But since there has to be a path provided, AutoCAD automatically puts in the default.
Then you can use that default path as your value to be appended to.
Good Luck
krzysztof.psujek
Hi, you can check Lee Mac's funcions
http://www.lee-mac.com/addremovesupportpaths.html
chris.neelin
SeeMSixty7
This works perfectly thanks so much for your help and prompt response
