Trying to get dynamic property value using LM function, won't recognize dynamic block?
Gorra
Gorra
Hello
I am trying to select all dynamic blocks of one type and get from each the "SPLICE GRIP X" and "SPLICE GRIP Y" properties. I'm using the same group select function I always use, and using the LM:getdynpropvalue function, I'm not seeing why I'm getting this -
; error: bad argument type: VLA-OBJECT nil
I assume this means the blocks aren't being recognized as dynamic?
The LISP is here:
(defun c:FixSC ( / SnapHold out Sp_blk GripDistX GripDistY Insert_X Insert_Y Insert_Z AnnoGripDist )
 (vl-load-com)
 (setvar 'attdia 0)
 (setq SnapHold (getvar 'osmode))
 (setvar 'osmode 0)
 (defun SelSpCs (/ e name n ss)
    (if (setq name "SPLICE CLOSURE";;;selecting all dynamic blocks of this name
        ss (ssget "_X" '((0 . "INSERT")))
            n -1
            out (ssadd)
        )  ;end setq
        (while (setq e (ssname ss (setq n (1+ n))))
            (if (= :vlax-true (vla-get-IsDynamicBlock (vlax-ename->vla-object e)))
            (if (= (strcase (vla-get-Effectivename (vlax-ename->vla-object e))) (strcase name))
                (ssadd e out)
            ) ;end if
            ) ;end if
        ) ;end while
    ) ;end if
    (sssetfirst nil out)
 ) ;end SelSpCs
  (defun LM:getdynpropvalue ( blk prp / x) ;;get grip X, get grip Y
    (setq prp (strcase prp))
    (vl-some '(lambda ( x ) (if (= prp (strcase (vla-get-propertyname x))) (vlax-get x 'value)))
        (vlax-invoke blk 'getdynamicblockproperties)
 (defun core ( / sb OldIns NewIns TrgIns_X TrgIns_Y)
    (SelSpCs)
    (foreach sb (vl-remove-if 'listp (mapcar 'cadr (ssnamex out)))
        (progn
           (setq GripDistX (LM:getdynpropvalue sb "SPLICE GRIP X"))
           (setq GripDistY (LM:getdynpropvalue sb "SPLICE GRIP Y"))
           (princ GripDistX)
           (princ GripDistY)
        ) ;end progn
    ) ;end foreach
 ) ;end core
 (core)
 (setvar 'osmode SnapHold)
I've attached the block below
Thanks for any help
paullimapa
your problem occurs in the core function here:
this code returns a list of entities and not vl objects
so when you execute the foreach loop you have to convert those items from entities to vl objects:
           (setq GripDistX (LM:getdynpropvalue (vlax-ename->vla-object sb) "SPLICE GRIP X"))
           (setq GripDistY (LM:getdynpropvalue (vlax-ename->vla-object sb) "SPLICE GRIP Y"))
Paul Li
IT Specialist
@The Office
Gorra
Ah, thanks, I thought it would be something like that.
paullimapa
glad to have helped...cheers!!!
Paul Li
IT Specialist
@The Office
Sea-Haven
Some of us just step through the selection set using repeat, handy at time when a selection set crashes as can track X value as item in selection set.
; this works last to first
(repeat (setq x (sslength ss))
  (setq obj (vlax-ename->vla-object (ssname ss (setq x (- x 1)))))
the other works first to last
(setq x -1)
(repeat (sslength ss)
(setq obj (vlax-ename->vla-object (ssname ss (setq x (1+ x))))))
