Trying to delete useless nodes on polylines
Message 1 of 17
Hello everyone!
As in the title, im looking for a way to programatically delete nodes that are creating collinear segments in polylines; I need to do that because im using those segments to annotate parcels. Polylines are created with (COMMAND "_boundary" point ""), extra nodes appear when there are lines starting or crossing the boundary perimeter.
I tryed a Lisp that i found somewhere in the web called PLDiet, making little changes to turn it from a command to a function, but it isnt working (original PLDiet didnt work neither), it runs succesfully but fails to clear all extra nodes . I havent succeeded yet in creating an efficient routine without help, sadly...
I attach a sample dwg ( im trying to process the red polyline), and here is the original PLDiet.lsp link. http://cadtips.cadalyst.com/linear-objects/polyline-diet
Any tip or help is welcome!
Thanks!!
Replies (16)
Message 3 of 17
Kent1Cooper
As the author of PLDIET, I can explain why it doesn't work in that case.  It's affected by where  Boundary decides to start the Polyline [I did a Boundary in the upper of the horizontal areas to the left, and PLD did  straighten the resulting 3-segment top edge].  [Curiously, I find that Boundary doesn't  put in vertices at those endpoints of outside things that meet the edges in all cases -- it didn't for me in the L-shaped area.]
PLD heads out from the first vertex [and it can't do anything with that -- it was written with things like contour lines in mind, which are seldom closed, and it isn't going to eliminate their endpoints].  In your example, that's the middle  of the right edge, so it can't straighten through that one.  It proceeds from there, and for every vertex, because of certain things about the way it analyzes, it needs to look two  vertices ahead from each vertex it might be able to remove.  The quarter-point vertex up from the bottom of the right edge in your example is the next-to-last  one [counting the Close to the start-point as the last one], so there aren't  two more from there, and it doesn't analyze that one.
I suppose it might be possible to alter it to handle the latter situation, but the former doesn't seem possible without a heck of a lot more analysis of the geometry of the Polyline.  BUT:
OVERKILL has this option:
which will handle the latter situation, but also won't do anything to the start/end vertex.  BUT:
Plain-old grip editing can  Remove even the start-end vertex:
[Select the Polyline, hover over a grip until it turns red, and type R.]
You could run PLDIET on all such things, and it should take care of many or most situations, leaving you only to "touch up" those with this kind of problematic geometry.  Or, if you do this a lot on always-rectangular and always-orthogonally-oriented  areas, a routine could be written pretty easily that would just replace  such resulting rectangles, no matter where they start or how many vertices may occur along any edge, with "clean" ones.
Kent Cooper, AIA
Message 4 of 17
Kent1Cooper
[The Swamp wants a log-in, and I'm not a registered User there, so I don't know about that one.]
The other one looks interesting, but it's not apparent from their image whether it would eliminate the start/end  vertex of a closed  Polyline, if that's in the middle of a straight edge as in the OP's example.
And it looks like it depends solely on the lengths  of edges, straightening only series of edges shorter than a specified length.  But in certain circumstances such as the OP's situation, you might need, in order to avoid straightening certain bends, to set the target length to a small enough distance that it wouldn't  clear some collinear vertices that it should.  By contrast, PLDIET [apart from the start/end-area limitation in my previous Reply] will eliminate all  vertices, no matter how far apart, in a collinear stretch, no matter how long it is [I think that's part of the reason it has to look 2 vertices ahead from each one under consideration, but it's been a while...].
That question of straightening bends you don't want straightened is why PLD has a maximum-amount-of-change-in-direction  setting, so [if you want] you can prevent the left image here from being turned into the right one, even if that short segment is much shorter than the target length.
Kent Cooper, AIA
Message 5 of 17
Kent, based on what you said i was pointed in the correct way when i tryed my own program, but obviously you guys had a way more advanced way to do it. Im thinking a method that would consist on extract the polyline's nodes in a list, count them, then APPEND it to itself. From there i would compare angles of 1º and 2º point with 2º and 3º, and if they are aqual (or very close), delete the 2º point from the list and set the counter to (- counter 1), and so on. Finally i would have to retrieve the first 'counter' elements of the list and entmake a polyline with them... i have to code it, but tell me if you ppl see something wrong in my plan, please
Message 6 of 17
Kent1Cooper
Something like that may work if you're only trying to eliminate vertices in the middle of collinear stretches, and don't want to bother evaluating small degrees of bend angle or deal with the possibility of arc segments [parts of what makes PLDIET so much more complicated].  But it still won't be able to eliminate that start/end vertex in the middle of a straight side, unless something about your Appending idea is for that [I confess I don't quite understand the purpose of the Appending].
Kent Cooper, AIA
Message 7 of 17
I had a free hour and i started trying and....
FINALLY! I have a way to improve your PLDiet lisp, Kent!
I did this:
+made a polyline with boundary command
+PLDiet on it
+made a list of nodes of the resulting polyline
+ENTDEL polyline
+change the initial node on the list to a middle one
(SETQ lst
     (APPEND
          (MEMBER (NTH (/ (LENGTH lst) 2) lst) lst)
          (REVERSE (CDR (MEMBER (NTH (/ (LENGTH (REVERSE lst)) 2) lst) (REVERSE lst))))
+reconstruct a new polyline from that list
+PLDiet again
and DONE! 😄
BUT i still lose the arcs,:(
thats a job for real masters 😛
Message 8 of 17
It makes the routine a bit slower, but im still happy 😄
Kent, its possible for you to add some lines to PLDiet to do this, but retaining arcs?
Message 9 of 17
Kent1Cooper
Quick perusal, so I may be misreading something, but I think I see a potential issue:
Since it seems to construct a replacement Polyline that simply starts about halfway around the original one, might it not sometimes end up with its new start/end vertex in the middle of a different  straight edge, with the same effect that PLD can't straighten across it?
Kent Cooper, AIA
Message 10 of 17
I guess that issue could happen if you have a triangle, with 4 nodes... But for any other polygon that works. I think it can be fixed by testing how many nodes are there in the polyline, if there are 4, it should PLDiet a new polyline starting in each node... I dont worry about that, since i dont work with triangles, but a general application should think about all posibilities 😛
Also, this approach can fail with 3-node plines, and its assuming that thay are all closed...
Message 11 of 17
I've been trying to get access to your lisp - it sounds like the perfect solution! However, not seeing places online to download it anymore. Is it still available / do you know if it still runs in ACAD 2018?
Message 12 of 17
dlanorh
Look HERE
I am not one of the robots you're looking for
Message 13 of 17
Jedi mind tricks don't work on me
Message 14 of 17
dlanorh
I'm a robot and thus precluded from using the force.
Message 15 of 17
Kent1Cooper
Try >this<, which should be the same as the link in Message 1.
Kent Cooper, AIA
Message 16 of 17
Kent1Cooper
@Kent1Cooper wrote:
@Anonymous wrote:
.... Is it still available / do you know if it still runs in ACAD 2018?
... or, the attached, which is the same except for having the (vl-load-com) line added that you will need if it hasn't been done already in your current session.
And I just tried it in Acad2019, successfully.
Kent Cooper, AIA
Message 17 of 17
Kent1Cooper
@Kent1Cooper wrote:
.... for every vertex, because of certain things about the way it analyzes, it needs to look two  vertices ahead from each vertex it might be able to remove.  The quarter-point vertex up from the bottom of the right edge in your example is the next-to-last  one [counting the Close to the start-point as the last one], so there aren't  two more from there, and it doesn't analyze that one.
I suppose it might be possible to alter it to handle the latter situation....
Updated version >here< handles that situation.
Kent Cooper, AIA
