Exporting File Sizes before and after purging to CSV
Message 1 of 9
We have many thousands of drawing. We have lisp routine to purge the drawing with out our intervention. What we need is LISP routine to generate a report in CSV with following columns. I know how to do this to generate .txt file but don't know the .CSV one
Date , File Name,  File Size before,  File Size After, Change in file size.
Appreciate help on this.
Hardik
Accepted solutions (3)
Replies (8)
Message 2 of 9
krzysztof.psujek
Hi, you can use LeeMac function to export data you have to csv.
Look here for the function and description
http://www.lee-mac.com/writecsv.html.
Chris
Message 3 of 9
pbejse
Hardik
Very close, check it out.
 Drawing Purge [ Ajilal Vijayan ] with Export To CSV option
Message 4 of 9
roland.r71
Hardik
A.csv file basically is a .txt file
The only difference is that you 'separate' parts of the file by a special sign. The C stands for 'comma' but in reality people use all sorts of chars.
I personally prefer to use ; others use [tab].
So, to write a csv file is the same as writing a txt file.
Except you write each line as a database record, with Comma Seperated Value's.
Top row usually contains the headers.
So, you can litterary write your line:
to a .txt (ASCII) file, which you just name .csv
Using the same method:
(setq csvfile (open "c:/temp/mydata.csv" "w"))
(write-line "Date , File Name,  File Size before,  File Size After, Change in file size" csvfile)
(close csvfile)
Message 5 of 9
Thanks, I have routine now but it repeats the header row for each file. Can you help with that?
Message 6 of 9
roland.r71
You probably included it inside the same loop where you write the lines.
First open the file, then write the headers.
After that, start any while or foreach loop to write the data.
Finally close the file.
Message 7 of 9
roland.r71
Example with writing separate header:
(setq dataList (list "18-9-2017, my1st.dwg, 1 kB, 201 kB, 200 kB"
                     "19-9-2017, my2nd.dwg, 100 kB, 250 kB, 150 kB"
                     "19-9-2017, my3rd.dwg, 150 kB, 100 kB, -50 kB")
(setq csvFile (open "C:/temp/myCSV.csv" "w"))
(foreach dataLine dataList
   (write-line dataLine csvFile)
(close csvFile)
Example with all data combined in 1 list:
(setq dataList (list "Date , File Name,  File Size before,  File Size After, Change in file size"
(close csvFile)
Of course, the var dataList can be a list of lists.
(list
   (list "Date" "Filename" "Filesize before" "Filesize after" "Change in filesize")
   (list "18-9-2017" "my1st.dwg" "1 kB" "201 kB" "200 kB")
etc.
In which case you might need to add a "foreach" or "while" loop for each item and add the separator inbetween.
Or just:
(write-line (strcat (nth 0 dataLine) "," (nth 1 dataLine) "," (nth 2 dataLine) "," (nth 3 dataLine) "," (nth 4 dataLine)) csvFile)
Message 8 of 9
roland.r71
If you want to write to the file from each dwg, use something like:
(setq date       "19-09-2017"
      filename   "my1st.dwg"
      sizeStart  "1 kB"
      SizeEnd    "201 kB"
      difference "200 kB"
dataLine (strcat date "," filename "," sizeStart "," sizeEnd "," difference) ) (setq csvFile "C:/temp/myCSV.csv") (if (findfile csvFile) ; if it exists (open csvFile "a") ; append to file ; else (progn (open csvFile "w") ; create file & add headers (write-line "Date , File Name,  File Size before,  File Size After, Change in file size" csvfile) ) ) (write-line dataLine csvFile) ; write data to file
(close csvFile)
This will create the file, if it doesn't exist & add the headers before writing the data.
Otherwise it will just append the new data to the existing file.
Message 9 of 9
Thanks roland.r71 for help.
You guided me correctly, the code in you solution was giving error for CSV file path. Here is final code that worked for me like a champ.
(defun c:writeCSV ()
	(setq 	date (TODAY)
		TIMEin (TIME)
		dwgfn (getvar 'DWGNAME)
		dwgdp (getvar 'DWGPREFIX)
		dwgfp (strcat dwgdp dwgfn)
		fs1 (vl-file-size dwgfp)
 	);setq
	(setq file (findfile "C:/Temp/LOG.csv"))
	(if (not file)
		(write-line "Date , timein, timeout, Dwg_Name, File_size_1,  File_Size_2, File_Size_Change" (open "C:/Temp/LOG.csv" "w"))
		(if (/= dwgfn "Drawing.dwg")
		(progn
			(setq csvfp (open file "a"))
		    (Command "qsave")
			(setq fs2 (vl-file-size dwgfp))
			(setq TIMEout (TIME))
			(setq d1 (strcat date "," TIMEin "," TIMEout "," dwgfn ","  (itoa fs1) "," (itoa fs2) "," (itoa (- fs1 fs2))));setq
			(princ d1 csvfp)
			(princ "\n" csvfp)
			(close csvfp)
			(princ (strcat "\nLogged out at : " TIMEout))
        );progn
	);if
	);if
	(princ)
	;(command "close")
