trouble testing members in a foreach loop.
mid-awe
mid-awe
Hi all,
I am having difficulty with:
(DEFUN C:TBOM ()
  (FOREACH I '("BOMPC_VENTURI" "BOMP3_VENTURI" "BOMPV_VENTURI" "BOMP3A" "bomcya" "BOMCYI" "BOMPCA" "BOM_dPC" "BOM_iPC" "BOM_ePC" "BOM_dP3" "BOM_iP3" "BOM_CiP3" "BOM_eP3" "BOM_dPV")
    (IF	(EVAL (MEMBER (STRCASE I) '("BOMPC_VENTURI" "BOMPCA" "BOM_DPC" "BOM_IPC" "BOM_EPC" "BOM_DPV")))
      (PRINC "\n\t => MATCH \n")
      (PRINC "\n\t => NOT MATCHED \n")
  (PRINC)
Obviously a simple test, but I am trying to get a match without regard to string case.
Any help and/or suggestions are greatly appreciated (even if I'm missing something stupid 😉 ).
ВeekeeCZ
Omit EVAL function. You're matching strings...
(DEFUN C:TBOM ()
    (IF	(MEMBER (STRCASE I) '("BOMPC_VENTURI" "BOMPCA" "BOM_DPC" "BOM_IPC" "BOM_EPC" "BOM_DPV"))
  (PRINC)
mid-awe
Thank you. I guess I just needed another pair of eyes. 🙂
I greatly appreciate it.
ВeekeeCZ
You're welcome 🙂
Actually, my explanation was wrong... IF function tests return of MEMBER function - which is in case of positive match a list (= true), otherwise nil. No place for EVAL function.
