[ToString function] variables conversion function to string
5 REPLIES 5
aqdam1978
2669 Views, 5 Replies
I want to write content of variables to a text file but I should have conversion function for variables.
for example
(setq a 123); a is an integer type, contetnt of a is 123
so I should use (itoa a) to get "123" as a string and then I can write it to text file.
but what about another type of variables?
(defun ToString ( a / result)
(setq result "")
(cond
	((= (type a) 'ENAME)
		(progn (setq result "Entity names")))
	((= (type a) 'EXRXSUBR)
		(progn (setq result "External ObjectARX applications")))
	((= (type a) 'FILE)
		(progn (setq result "File descriptors")))
	((= (type a) 'INT)
		(progn (setq result (itoa a))));;"Integers"
	((= (type a) 'LIST)
		(progn (setq result "Lists")))
	((= (type a) 'PAGETB)
		(progn (setq result "Function paging table")))
	((= (type a) 'PICKSET)
		(progn (setq result "Selection sets")))
	((= (type a) 'REAL)
		(progn (setq result (rtos a 2 3))));;"Floating-point numbers"
	((= (type a) 'SAFEARRAY)
		(progn (setq result "Safearray")))
	((= (type a) 'STR)
		(progn (setq result a)));;"Strings"
	((= (type a) 'SUBR)
		(progn (setq result "Internal AutoLISP functions")))
	((= (type a) 'SYM)
		(progn (setq result "Symbols")))
	((= (type a) 'VARIANT)
		(progn (setq result "Variant")))
	((= (type a) 'USUBR)
		(progn (setq result "User-defined functions loaded from LISP source files")))
	((= (type a) 'VLA-object)
		(progn (setq result "ActiveX objects")))
Result
5 REPLIES 5
pbejse
in reply to: aqdam1978
for example
Would you want the "value" of the variable to write to string?
for example  (setq a '(1.2 2.5 0.0))
(type a) = LIST
write to string --- > "(1.2 2.5 0.0)" and not "lists" as you have shown on your code?
aqdam1978
in reply to: pbejse
yes, exactly, because I can't write any variables in a text file except string variables!
pbejse
Its easy. waht you need is an association list .
NOT sure why you need to write to string the "other types" but you may need to add an function to evaluate the variable value and convert it to a string like the one on your sample
(INT (itoa a))
(eval..  will evaluate the second element
(defun ToString  (a / result)
  (eval (cadr (assoc (type a)
                     '((ENAME "Entity names")
                       (EXRXSUBR "External ObjectARX applications")
                       (FILE "File descriptors")
                       (INT (itoa a))
                       (LIST (vl-princ-to-string a))
                       (PAGETB "Function paging table")
                       (PICKSET "Selection sets")
                       (REAL (rtos a 2 3))
                       (SAFEARRAY "Safearray")
                       (STR a)
                       (SUBR "Internal AutoLISP functions")
                       (SYM "Symbols")
                       (VARIANT "Variant")
                       (USUBR "User-defined functions loaded from LISP source files")
                       (VLA-object "ActiveX objects"))))
As for the other types, i' leave that to you to figure out the functions
HTH
EDIT: That was you question, silly me... I woiuld love to play but you need to give an example for each type then i can point you in the right direction.
aqdam1978
in reply to: pbejse
Hi Pbejse,
you are hero!
I just want to have general function to convert all types of variable to string.
I call it ToString.
for exaple see the "ToString" function usage in this code:
(defun c:GetSystemInfo(/ item meth1 meth2 process wmi fn des)
	(defun ToString  (a)
						   (INT (itoa a))
						   (REAL (rtos a 2 3))
						   (STR a)
						   (SYM "Symbols")
						   (VARIANT "Variant")
	(defun lister(val / it)
		(vlax-for it val
		(if (vlax-get it 'value)
		(write-line (strcat (vlax-get it 'name) " : " (ToString (vlax-get it 'value))) des)
		);;if
		);;vlax
(vl-load-com)
(setq fn "D:\\SystemInfo.txt")
(setq des (open fn "w" ))
(setq WMI (vlax-create-object "WbemScripting.SWbemLocator"))
(setq meth1 (vlax-invoke WMI 'ConnectServer nil nil nil nil nil nil nil nil))
(write-line "------------------------------------------------------------" des)
(foreach process (list "BIOS" "Processor" "VideoController" "SoundDevice" "CDROMDrive" "OperatingSystem" "ComputerSystem" "PhysicalMemory" "DiskDrive")
	(setq meth2 (vlax-invoke meth1 'ExecQuery (strcat "Select * from Win32_" Process)))
	(write-line (strcat "<<< features of " process " >>>:\n------------------------------------------------------------") des)
	(vlax-for item meth2
		(lister (vlax-get item 'Properties_))
		(lister (vlax-get item 'Qualifiers_))
);;foreach
(close des)
(mapcar 'vlax-release-object (list meth1 meth2 wmi))
(startapp "Notepad" fn)
(princ)
 Thank you for all of your helps and supports.
Abbas
pbejse
it that case you dont need a fancy sub to convert all the values to string
vl-princ-to-string will suffice
(defun lister (val file / it)
		(vlax-for it val
		(write-line (strcat (vlax-get it 'name) " : " (vl-princ-to-string (vlax-get it 'value))) file)
		);;if
		);;vlax
		(lister (vlax-get item 'Properties_) des)
		(lister (vlax-get item 'Qualifiers_) des)
HTH
Autodesk Customer Advisory Groups
