Too few arguements
Too few arguements
Too few arguements
I have a slate of pre-defined colors that I use to programmatically control layers.
I am writing a routine to draw a chart showing the color number, a solid showing the specified color as a square, and below that the name of the variable that contains the color.  My problem is that when I call (drawmark), it will not even run. It reports "Too few arguments".  Does anyone else get this error? What is causing it?
;define the color variables
(setq CLR-RED1 241 CLR-RED2 230 CLR-RED3 1 CLR-RED4 242 CLR-RED5 244)
;get the start point and calculate all required points (easier to debug)
(defun MARKPOINTS (/ PT P1 P2 P3 P4 BDRPTS& CNUMTXPT CLRSQPTS& CNAMTXPT C)
   (setq PT (getpoint "\nPick upper left point"))
  (setq P1 PT P2 (polar P1 0 20) P3 (polar P2 (* PI 1.5) 30) P4 (polar P1 (* PI 1.5) 30))
  (setq BDRPTS& (list P1 P2 P3 P4))
  (setq C (polar PT 0 10))
  (setq C (polar C (* PI 1.5) 8))
  (setq CNUMTXPT C)
  (setq C (polar C (* PI 1.5) 2))
  (setq P1 (polar C PI 5) P2 (polar C 0 5) P3 (polar P2 (* PI 1.5) 10) P4 (polar P1 (* PI 1.5) 10))
  (setq CLRSQPTS& (list P1 P2 P4 P3))
  (setq C (polar C (* PI 1.5) 18))
  (setq CNAMTXPT C)
  (list BDRPTS& CNUMTXPT CLRSQPTS& CNAMTXPT)
;draw the mark and label it
(defun DRAWMARK (\ PTS& OSM CLR)
  (setq PTS& (markpoints))
  (command "_.PLINE") (foreach F_PT (car PTS&)(command F_PT)) (command "c")
  (command "_.TEXT" "J" "C" (cadr PTS&) "6" "0" CLR "")
  (command "_.SOLID") (foreach F_PT (caddr PTS&)(command F_PT)) (command "")
  (setq CLR (itoa (eval (read VARNAM))))
  (command "_.CHPROP" "L" "" "C" CLR "")
  (command "_.TEXT" "J" "C" (cadddr PTS&) "6" "0" (substr VARNAM 5) "")
  (prin1)
(setq VARNAM "CLR-RED1") ;set a global variable with the name of the variable
(drawmark)      ;call the routine
Ranjit_Singh
Try changing this line
to
(defun DRAWMARK ( / PTS& OSM CLR)
I am not on the computer right now and cannot check the code. Maybe someone else can test.
john.uhden
The problem is in:
The backslash should be a forward slash, "/"
AutoCAD is interpreting your backslash as an argument symbol name.
If you were to call the function with 4 arguments, it would work accordingly...
(drawmark "A" "B" "C" "D)
would read \ as "A", and PTS& as "B", etc.
Changing the backslash to a foreslash would treat PTS&, OSM. and CLR as locals, which I think you intended.
John F. Uhden
That fixed it.  Couldn't see the forest with all the trees in the way.  Thanks
john.uhden
Learning is what keeps us young (said the old fart.)
John F. Uhden
