Replace " with \" in a string
svucic
svucic
Hi everyone,
as the title says i'm trying to replace the quotes in a path with \".
Example:
"C:\\Users\\Something\\Desktop\\Something"
to
\"C:\\Users\\Something\\Desktop\\Something\"
ВeekeeCZ
What is it? Content of an (M)TEXT entity?
Spoiler
; if so, then getting string of a content
(cdr (assoc 1 (entget (car (entsel)))))
receive
"\"C:\\\\Users\\\\Something\\\\Desktop\\\\Something\""
Or a value of a STRING variable?
svucic
It's a value of a STRING variable.
ВeekeeCZ
Try this...
(strcat "\"" "C:\\Users\\Something\\Desktop\\Something" "\"")
or if you have a variable called filepath, then
(strcat "\"" filepath "\"")
which gives you
"\"C:\\Users\\Something\\Desktop\\Something\""
Outer quotation marks are a part of a string definition, can't omit those.
svucic
Wel, I'm using (setq DirPath (acet-ui-pickdir)) to get the path to a folder which I'm passing to an external program.
And the path that i'm passing to the program should be like this:
\"C:\\Users\\Srdjan\\Documents\\test.csv\"
Example of executing external program:
(dos_execute "program -input:\"C:\\Users\\Something\\Desktop\\Something\" -output:\"C:\\Users\\Something\\Desktop\\Something\" -definition:\"C:\\Users\\Something\\Desktop\\Something\"" 0)
ВeekeeCZ
Try something like this...
(setq filepath "C:\\Users\\Something\\Desktop\\Something")
(setq filepathquited (strcat "\"" filepath "\""))
(setq depars (strcat "program"
                     " -input:" filepathquited
                     " -output:" filepathquited
                     " -definition:" filepathquited))
(dos_execute depars 0)
Or, it may be more obvious without variables...
(dos_execute (strcat "program"
                     " -input:" "\"" filepath "\""
                     " -output:" "\"" filepath "\""
                     " -definition:" "\"" filepath "\"")
  0)
svucic
Works. Thank you BeeKeeCZ 🙂
