Toggle Viewport On/Off
Jonathan3891
Advisor Advisor
Jonathan3891
I am looking to create a lisp file that will toggle a selected viewport on/off.
I've done a lot of searching but haven't found anything similar to what I'm trying to do.
This is all I have so far but its not working. My idea was to see if I could have it show an alert if the viewport was on or off and build off that, but I'm stuck and I'm not entirely sure I'm going about this the right way.
(vl-load-com)
(defun c:ttt (/ )
  (setq VP (ssget))
  (setq targetvp (vlax-ename->vla-object (ssname VP 0)))
  (if (=(vla-display targetvp :vlax-true))
    (alert "true")
  (alert "false")
Jonathan Norton
Blog | Linkedin
ronjonp
You need to use: vla-put-ViewportOn
ronjonp
Here's a quick example:
(defun c:foo (/ o s)
  ;; RJP » 2019-07-26
  ;; Toggle viewport on status
  (if ;; Filter viewport objects
      (setq s (ssget ":L" '((0 . "viewport"))))
    ;; Iterate over selection set
    (foreach x (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
      ;; Convert to vla-object
      (setq o (vlax-ename->vla-object x))
      ;; Toggle on off status
      (vlax-put o 'viewporton (boole 8 0 (vlax-get o 'viewporton)))
  (princ)
(vl-load-com)
Jonathan3891
That's exactly what I was looking for!
I new I was going about this the wrong way. I'm still learning LISP and fairly new to VLA.
Thank you!!!
Jonathan Norton
Blog | Linkedin
ronjonp
Glad to help 🙂
