Toggle Drawing Modes Not Activated (F3: Object Osnap, etc.)
Blissab
Blissab
AutoCAD LT 2020, the Toggle Drawing Modes, such as, F3:  Object Osnap, does not seem to be activated on my computer.  How do I activate these shortcuts?
Sea-Haven
If its out of the box then F3 should work, but if you have no osnaps set then you will see nothing changing, type osmode 47 this will set some osnaps for you hopefully even in LT, you can change your osnap settings by using "osmode" then the correct number you can find the number by setting osnaps via dislouge then type osmode and the setting number will appear.
