Programming Challenge 8/22
Sea-Haven
Mentor Mentor
Sea-Haven
I though an interesting challenge would be make a simple dcl code by selecting objects.
So for radio buttons start with a block called radiobutton with 1 attribute the description. Say select heading a text, the Ok, Ok_cancel again text. Just window say the buttons.
Ok if you want to compare some code have  a look at my multi radio Buttons.lsp and change the vl-filename-mktemp to a dcl name and see the resulting code. I am sure plenty out there could use a dcl generator. I use yes / no all the time.
Oh the obvious is make all 3 into 1 dcl. Or Multi column radio button dcl etc.
john.uhden
@Sea-Haven
Hi, Alan.
After all this time, I thought you deserved a response...
I don't get it.
You Aussies are so far ahead, what with winged keels and Ash Barty and all that stuff.
John F. Uhden
Sea-Haven
Yeah I need to get back to it, I thought it would be useful writing dcl code that you know will work. Rather than missing one bracket or semicolon somewhere.
diagodose2009
Here you view my demo,
These files*.txt, you rename *.txt with *.dcl
You press the button "Zip" for bCanExit;
Ms-Dos applications=Arj.exe, Rar.exe, Zip.exe, Cpkunzip.dll, VolkovCommander,Nc=NortonCommander.
If you need more-Customization of DCL, then you send P.M. here on ->
Sea-Haven
Its about select say a column of blocks and the lisp code or dcl code is produced. It is preferred that the code produced does write-line of each line of the dcl, the dcl code is then pasted into the lisp code.
(setq fo (open (setq fname (vl-filename-mktemp "" "" ".dcl")) "w"))
(write-line  "AHbutts : dialog 	{" fo)
(write-line  (strcat "	label =" (chr 34) (nth 0 butlst) (chr 34) " ;" )fo)
(write-line "	: row	{" fo)
It would be like a dcl generator, I know some are out there but expensive for say a simple single column dcl.
Maybe start with column of text, as labels and choose type radio, value or toggle.
YES
NO
1
2
3
4
diagodose2009
We have DCL-generator, but You need,  these step/s
A)transform DCL to procedure/s (store,call,load and save on disk)
B)the tokenizer the variabiles-inside-LISP  BY defun C:
C)compact DCL into strings.
D)parse DCL and extract action/s to list-with-function-s
E)Customize the messages from  DCL, with variabiles/from/autolisp.
-- IF you hire me, then I can develop for you , I can develop many DCL, types,  or huge files.DCL with
  • OurGenerator.of-DCLdll(fast mode)
  • OurGenerator.dll can export DCL and source-lisp, both files type/s.
F)Store-the file*. DCL  on the web,
G)downloading the files*.DCL  inside Acad.exe
H) set default/s values for toggles.(1=enable 0=disabled)
J)
