To draw a 3dpolyline by point list
devitg
Advisor Advisor
Message 1 of 17
devitg
Hi all user, How I can make a 3DPOLY by a points list as follow , please give 3 ways , by COMMAND, ENTMAKE, and VLA-ADD3DPOLY.
Thanks in advance
(setq pt-list '((0.0 0.0 0.0) (120.0 0.0 75.0) (120.0 64.0873 150.0) (0.0 64.0873 75.0)) )
Replies (16)
Message 2 of 17
ВeekeeCZ
One way or another. Have fun.
(setq pt-list '((0.0 0.0 0.0) (120.0 0.0 75.0) (120.0 64.0873 150.0) (0.0 64.0873 75.0)))
(defun c:onewaytogo ()
  (command "_.3dpoly")
  (foreach pt pt-list (command "_non" pt))
  (command "")
(defun c:secondwaytogo ()
  (entmake '((0 . "POLYLINE") (70 . 8)))
  (foreach pt pt-list (entmake (list '(0 . "VERTEX") '(70 . 32) (cons 10 pt))))
  (entmake '((0 . "SEQEND")))
(defun c:thirdwaytogo ()
  (setq pts (apply 'append pt-list))
  (vla-Add3DPoly
    (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object)))
    (vlax-safearray-fill (vlax-make-safearray vlax-vbDouble (cons 0 (1- (length pts)))) pts)
(defun c:thirdwaybyfollowinghelp ()
    ;; This example creates a 3 segment 3D polyline in model space.
    (setq acadObj (vlax-get-acad-object))
    (setq doc (vla-get-ActiveDocument acadObj))
    ;; Create the array of points
    (setq points (vlax-make-safearray vlax-vbDouble (cons 0 (1- (length pts)))))
    (vlax-safearray-fill points pts
    ;; Create a 3D polyline in model space
    (setq modelSpace (vla-get-ModelSpace doc))
    (setq polyObj (vla-Add3DPoly modelSpace points))
    ;(vla-ZoomAll acadObj)
(defun c:fourthwaytogo ()
  (vlax-invoke
    'add3dpoly
Message 3 of 17
Kent1Cooper
Don't forget the question of whether or not the result should be closed.
Kent Cooper, AIA
Message 4 of 17
devitg
@Kent1Cooper , Hi Kent , not at this case .
It will be OPEN.
Message 5 of 17
devitg
@ВeekeeCZ Thanks .
Message 6 of 17
devitg
@ВeekeeCZ Thanks a lot, it helps me to understand some questions I had about all these ways to do .
Message 7 of 17
devitg
@ВeekeeCZ Hi, given your good will to help us , please give some hints to use
VLAX-INVOKE
As to get PROPIERTIES, or to apply METHOD.
This , solve it for METHOD.
(vlax-invoke
    'add3dpoly
But I not get propierties like
  (setq 3dpol-xyz (group-by-num/list-num(VLAX-SAFEARRAY->LIST (VLAX-VARIANT-VALUE (VLA-GET-COORDINATES 3dpol)))3))
3DPOLY is an OBJECT I tried with
  (setq 3dpol-xyz (vlax-invoke 'coordinates 3dpol))
it return
  ; error: bad argument type: VLA-OBJECT COORDINATES
Neither have any result with
(setq 3dpol-xyz (vlax-invoke  3dpol 'coordinates))
  Thanks, in advance.
I like to handle vla-objects , but for some task I need  ENTities  data .
As to do an SSGET FENCE
(setq point-ss (ssget "F" 3dpol-xyz (list (cons 0 "point") (cons 8 CLAYER))))
Message 8 of 17
ВeekeeCZ
The simplest way how to get coordinates is
(vlax-get 3dpol 'coordinates)
>> (213.735 267.599 250.021 267.599 250.021 237.729 213.735 237.729)
That way you don't need to deal with variants and safearrays.
Message 9 of 17
devitg
@ВeekeeCZ  Ok, but then I need to group the coordinates to xyz, x1y1z1, abd so on, to use it at a ssget "F"
I have a defun to group-by-num
Thanks for your help
Message 10 of 17
daniel_cadext
You can use a COM selection set, it’s already formatted.
Python, but you can do this in lisp.
import traceback
from pyrx_impx import Rx, Ge, Gi, Db, Ap, Ed, Ax
def PyRxCmd_xdoit() -> None:
    try:
        axApp = Ax.getApp()
        axDoc = axApp.ActiveDocument
        entsel = axDoc.Utility.GetEntity("\nPick it like you mean it: ")
        pl = Ax.IAcad3DPolyline(entsel[0])
        axSs = axDoc.SelectionSets.Add("AXTBLSS")
        axSs.SelectByPolygon(
            Ax.constants.acSelectionSetFence,
            pl.Coordinates,
            [0], ["ACAD_TABLE"])
        print(axSs.Count)
    except Exception as err:
        traceback.print_exception(err)
    finally:
        axSs.Delete()
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
Message 11 of 17
devitg
@daniel_cadext , Sorry I do not understand it. Please clear me.
Message 12 of 17
Kent1Cooper
@devitg wrote:
.... then I need to group the coordinates to xyz, x1y1z1, abd so on, to use it at a ssget "F"  ....
This topic started with a list of points to use to draw a 3D Polyline.  Now you want to extract the vertices of a 3D Polyline to use for Fence selection?  Just use the original list of points -- there's no need for the middle-man Polyline.  Am I missing something?  Are there two separate goals here, un-related?
Kent Cooper, AIA
Message 13 of 17
ВeekeeCZ
Then try this example
(defun group-by-three (lst / rtn)
  (if lst (repeat (/ (length lst) 3)
	    (setq rtn (cons (list (car lst) (cadr lst) (caddr lst)) rtn)
		  lst (cdddr lst))))
  rtn)
(defun c:Fencesel ()
  (setq ent (car (entsel "Select 3dpolyline: ")))
  (setq obj (vlax-ename->vla-object ent))
  (setq coo (vlax-get obj 'coordinates))
  (setq xyz (group-by-three coo))
  (setq pts (ssget "_F" xyz (list '(0 . "point") (cons 8 (getvar 'clayer)))))
  (if pts (sslength pts))
Message 14 of 17
devitg
@Kent1Cooper  it is part a whole lsp .
Message 15 of 17
daniel_cadext
"Sorry I do not understand it. Please clear me. "
I meant use vla-get-SelectionSets instead of ssget since you’re already using ActiveX
In this case 'coordinates should already be formatted correctly
https://help.autodesk.com/view/OARX/2022/ENU/?guid=GUID-D8002585-5D08-45E2-AF6C-6E894FA3D463
Message 16 of 17
ronjonp
@ВeekeeCZ  Might as well tidy up the code with localized variables and check that the selection is valid right?
(defun c:fencesel (/ group-by-three coo ent obj pts xyz)
    (if	lst
	      lst (cdddr lst)
    rtn
  (if (and (setq ent (car (entsel "Select 3dpolyline: ")))
	   (vlax-property-available-p obj 'coordinates)
    (progn (setq xyz (group-by-three coo))
	   (if pts
	     (sslength pts)
  (princ)
Message 17 of 17
Sea-Haven
Another check 2d 3d points
; convert now to xyz
(defun co-ords2xy (xyz / )
(setq co-ordsxy '())
(if (= xyz 2)
(progn
(setq I 0)
(repeat (/ (length co-ords) 2)
(setq xy (list (nth i co-ords)(nth (+ I 1) co-ords) ))
(setq co-ordsxy (cons xy co-ordsxy))
(setq I (+ I 2))
(if (= xyz 3)
(progn
(setq I 0)
(repeat (/ (length co-ords) 3)
(setq xy (list (nth i co-ords)(nth (+ I 1) co-ords)(nth (+ I 2) co-ords) ))
(setq I (+ I 3))
(setq obj (vlax-ename->vla-object (car  (entsel "Pick obj"))))
(setq co-ords (vlax-get obj 'coordinates))
(cond
  (( = (vla-get-objectname obj) "AcDb2dPolyline")(co-ords2xy 2))
  (( = (vla-get-objectname obj) "AcDb3dPolyline")(co-ords2xy 3))
(princ co-ordsxy)
