To Create Offset Lines
bedyr
Message 1 of 10
bedyr
Replies (9)
Message 2 of 10
kajanthangavel
I think, this posibile only 'Autocad Electrical'...😀
Message 3 of 10
bedyr
I think it is possible but we dont know how. 😁
Message 4 of 10
devitg
What ACAD  do you use???
Please upload a sample.dwg with a BEFORE and AFTER
Message 5 of 10
bedyr
I am using autocad for mac 2020. You can see link above what I am saying.
Message 6 of 10
cadffm
Find the different.
Sebastian
Message 7 of 10
bedyr
I know that. I am saying that can I create this option on autocad?
Message 8 of 10
cadffm
1. Not "in AutoCAD" but "in AutoCAD for MAC" (often an important different)
2. I don't know about this Option in detail, just from yourr Link, because i don't know "Autocad Design Utility"/"ADU"
3. Perhaps you are searching for the OBJECT SNAP PARALLEL ?
Sorry if not, i am out.
Sebastian
Message 9 of 10
Sea-Haven
Its very doable picking a sequence of lines or plines then drawing say two parallel lines along that route. I would expect something exists already. Maybe search for just that "Route lisp" there is a lot of  stuff out there if you use a car gps it has route built in. Check Cadtutor.net as well I think it was there. I have something but it would need a bit more smarts added to it as it was purpose written, draws 4 lines.
Message 10 of 10
bedyr
I want to like that lisp but in this lisp I couldnt change offset direction. Can we change this for two options?
I will click a point and with mouse action choose offset direction.
(defun c:PF (/ dd mm p1 p2 is nk1 nk2) (setq dd t) (setq mm 5) (setq obj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument obj)) (setq ms (vla-get-ModelSpace doc)) (if (setq p1 (getpoint "\nFirstPoint:")) (progn (while dd (if (setq p2 (getpoint p1 "\nOtherPoint:")) (progn (setq ss (ssget "c" p2 p2)) (if ss (setq is -) (setq is +) ) (setq nk1 p1 nk2 (polar p1 (angle p1 p2) (is (distance p1 p2) mm)) ) (vla-addline ms (vlax-3d-point nk1) (vlax-3d-point nk2)) (setq p1 nk2) ) (progn (setq dd nil) ) ) ) ) ) (princ) )
