To change a MLEADER as to a given LEADER
devitg
Advisor Advisor
devitg
Hi all , please help,  my task to do
I can made by lisp the green Mleader at the curren layer , but I need to change it's color as the LEADER color
How to change  the Mleader to be the same as the LEADER color
I try to do it by TRUE-COLOR property , but I can not understand . also I try by the ENGET from the MLEADER-ent, but I can not  did .
If possible, by VL-functions
Thanks in advance
pbejse
Leader colors are set via Dimension styles, same goes for Mleader using mleaderstyle But that's not your question is it?
If you want to force a color, the usual (Vlax-put ev 'color 1) should work. I'm honestly puzzled by your request @devitg  🙂
devitg
@pbejse Hi , thanks for your tip.
Pardon me if I puzzled  you.
And quoting The Little Prince , by Saint-Exupéry
The essential is invisible to the eyes.
