timer reactor
timer reactor
diegolopezsilanes
timer reactor
diegolopezsilanes
Hi, I have a lisp to switch the gripsize and i'd like to implement a reactor that
sets the gripsize to 5 after 5 seconds when the command runs.
I've been trying to manipulate the code from this page:
;https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/personal-infofield-in-statusbar/td-p...
and Im not dealing with the reactors
any help?
(defun C:CF ( );;Switch  GRIPSIZE 28-3-19
(SETQ PBB (GETVAR ' GRIPSIZE))
(IF (< PBB 35)
(SETVAR "GRIPSIZE" 35)
(IF (> PBB 6)
(SETVAR "GRIPSIZE" 5)
);IF
);IF
);DEFUN
Moshe-A
@diegolopezsilanes  hi,
it's better to solve such an issue inside the lisp, here is an example.
an error handle (*error*) should be added to cover a command break in middle.
moshe
(defun c:cmd (/ savGripSize)
  (setq savGripSize (getvar "gripsize")) ; save grip size
  (setvar "gripsize" 10)                 ; set new value
  ; do your command   ; .....   ; ....
  (setavr "gripsize" savGripSize) ; restore grip value   (princ) )
Sea-Haven
You could get the Date continuously till its 5 seconds past the 1st date value. this is approximate
(setq date (rtos (getvar "cdate") 2 6))
(setq sec (atoi(substr date 14 2)))
(setq sec (+ sec 5))
(setq sec2 (+ sec 0.001))
(while (< (- sec2 sec) 5.0)
(setq sec2 (atoi(substr (rtos (getvar "cdate") 2 6) 14 2)))
