Personal Infofield in Statusbar
C.Utzinger
Message 1 of 20
C.Utzinger
HI
How is it possible to show an personal Info at the Statusbar?
We have a additional program for AutoCAD and they made it (see attached printscreen)
Happy new Year!
Replies (19)
Message 2 of 20
cadffm
There is one "field" you can customize with text abd diesel expressions
F1 for MODEMACRO and DIESEL
Befehl: Modemacro
Mein Layer $(getvar,clayer)
Sebastian
Message 3 of 20
C.Utzinger
Is there only one?
Message 4 of 20
cadffm
Yes.
Example for Layer AND Layouttab
modemacro
Lay: $(getvar,CLAYER) | Tab: $(getvar,CTAB)
Sebastian
Message 5 of 20
C.Utzinger
In this case, the problem I have, that i must share this field with the other program.
From my side no problem with a lisp routine to add the Information to the existing text from the other program, but the other program will overwrite my Information when it changes the settings.
Grrrrrrr
Message 6 of 20
cadffm
Contact the program producers to change the software, he can handle it like you want to handle it.
save existing value
- replace with temorary information (during a command is active) and reset the old value after
- running informations should added to existing values
Sorry.
Plain AutoCAD are no custom fields possible, only with extensions .net/c++.
For example you can use a custom-PALETTE to display Informations, http://opendcl.com/wordpress/?tag=palette
If you want it better, the direction is C++ (or .net)
Sebastian
Message 7 of 20
DannyNL
Create a reactor that automatically adds your information to MODEMACRO again as soon as the information is changed by the other program.
Message 8 of 20
C.Utzinger
Hi I just testet it
But AutoCAD crashes when i use it... Smiley LOL
When I just put a alert then it shows up 3 times.
(vl-load-com)
(setq VTFRXN (vlr-editor-reactor nil '((:VLR-sysVarChanged . VTF))))
(defun VTF (CALL CALLBACK)
   (if (= (strcase (car CALLBACK)) "MODEMACRO")
       (progn
         (setq info (getvar 'MODEMACRO)
               info (vl-string-left-trim " /SPI-:1234567890" info)
               info (strcat "SPI- 1:50 / " info)
       (setvar 'MODEMACRO info)
Message 9 of 20
DannyNL
That actually makes sense since the reactor changes the MODEMACRO and thus triggers itself again.
You probably need to build some delay into it, something only to execute if the last change was more than, lets say 5 seconds ago. Maybe use the blackboard (vl-bb-set/ref) to write/read execution time for the reactor to check before executing again.
Message 10 of 20
C.Utzinger
It also crashes when I change the variable only one time...
Message 11 of 20
DannyNL
I've tested and can confirm I have the same issue and cannot seem to prevent it somehow.
But you say the MODEMACRO changes when the other program's settings are changed. Instead of using a reactor on the MODEMACRO variable, can't you use a reactor to catch the command used for changing the program's settings to modify the MODEMACRO back to what you want?
Message 12 of 20
ВeekeeCZ
You can try to use (grtext) if it helps you in your fight... But  it has its pros and cons... read THIS thread for more info...
Message 13 of 20
C.Utzinger
Please, do you have an example for a recator for a function?
Message 14 of 20
DannyNL
Something like this? Example used for the OPTIONS command.
Although I'm not certain it will be able to capture the commands of your program.
(vl-load-com)
(setq VTFRXN (vlr-editor-reactor nil '((:VLR-commandEnded . VTF))))
   (if (= (strcase (car CALLBACK)) "OPTIONS")
       (progn
If this doesn't work you probably will need to create some test reactors for different reactor types just to see what reactors your program command triggers and what not. But be careful, it is really easy (as you have noticed with the SysVar reactor) to crash AutoCAD, so make sure to save your code before each test.
Message 15 of 20
ВeekeeCZ
Yes, but too complicated to share. (edit: oops, did not see that your reply was to Danny)
Here is your modified.
(defun c:sysvarReactor-OnLoad ()
  (if *sysvarReactor* (vlr-remove *sysvarReactor*))
  (setq *sysvarReactor* (vlr-sysvar-reactor nil '((:vlr-sysVarChanged . sysvarReactor-CallBack))))
  (princ "\nSysvarReactor is running")
(defun c:sysvarReactor-UnLoad ()
  (if *sysvarReactor* (vlr-remove *sysvarReactor*)) (princ))
(defun sysvarReactor-CallBack (rea lst / ss)
  (if (= (strcase (car lst)) "MODEMACRO")
    (progn
      (grtext -1 info)
(c:sysvarReactor-OnLoad)
Message 16 of 20
C.Utzinger
HI, good news
This way it seems to work perfect.
(vl-load-com)
   (if (= (strcase (car CALLBACK)) "SETVAR")
       (progn
          (vl-catch-all-apply 'setvar (list "MODEMACRO" info))
Thank you! Kind regards
Message 17 of 20
C.Utzinger
Hi BeekeeCZ
your solution works also, but the grtext doesn't convince me.
Thank you anyway.
Kind regards
Message 18 of 20
C.Utzinger
HI
Some of my users have the following message:
Fehler: no function definition: VLR-EDITOR-REACTOR
 I could not find the problem why this happens. Perhaps you know a solution for it.
Best regards
Message 19 of 20
DannyNL
Assuming you did (vl-load-com) on those PC's and other VL-commands like (vlax-get-acad-object) work correctly, I've no idea.
All PC have the latest updates installed for your AutoCAD version?
Message 20 of 20
C.Utzinger
HI
I will check the updates.
But I remember there was a similar case, and until reinstallation of AutoCAD we could not fix it.
Thank you
Regards
