This isn't working and I am not sure why
Just creating some shortcuts for LDD.
Editing the routines to remove the menu marcos, but still not working at all. I should have known to remove those macro features. Anyhow, when I
try a command, what I get is:
Command: 3s
Loading AecCivilVol...
Command:
Command: 3c
Command:
Here is what things currently look like:
(DEFUN C:zt ()
(cr_mnl)(zz_sdsk '(progn (cg_zoompt)(princ)));LDD
(PRINC))
(DEFUN C:3e ()
(er_mnl)(zz_sdsk '(er_grdplnelev));LDD
(PRINC))
(DEFUN C:3s ()
(er_mnl)(zz_sdsk '(er_grdplnslp));LDD
(PRINC))
(DEFUN C:3c ()
(er_mnl)(zz_sdsk '(er_grdcurb));LDD
(PRINC))
(DEFUN C:3a ()
(er_mnl)(zz_sdsk '(er_grdaddvert));LDD
(PRINC))
Not sure what could be the problem.
Thanks much for any help you can provide.
(DEFUN C:zt ()
(cr_mnl)
(c:LDD);;note that the menu use of LDD must be revised like so
(PRINC)
wrote in message news:5082030@discussion.autodesk.com...
Command: 3s
Command:
Command: 3c
Command:
(DEFUN C:zt ()
(PRINC))
(DEFUN C:3e ()
(PRINC))
(DEFUN C:3s ()
(PRINC))
(DEFUN C:3c ()
(PRINC))
(DEFUN C:3a ()
(PRINC))
