text rotation / mirror in a block.
zafera5VK85
zafera5VK85
Dear Forum,
I've been waiting for years to Autodesk to solve the issue about text rotation / mirror in a block. Yet it has not been any update about it. Attribute an option but I'd insist to use Text in a block due to more control and justification. Is there anyway to correct text rotation and mirror in a block ?
Best Regards.
Victor
thaydenCJMLL
I don't understand which control and justification advantages you feel text or mtext has over  using an attribute?
You can control rotation of the attribute(s), independent of the block's insertion point... as well as justification, text style overrides, color overrides etc., etc. via the Enhanced Attribute Editor. And you can do this individually, on a block-by-block insertion basis if you want.
This controls properties of the attribute(s) in a block - not other geometry like lines, circles, etc.:
I'd use an attributes whenever possible inside a block that may be rotated or mirrored - there is much greater control over the readability - and they aren't affected if the block is mirrored..
devitg
@zafera5VK85 Why the original ?
Has the HW12a , mirrored
