text inside block border to its attribute
the_ameral
the_ameral
i have texts in 3 layers(layer1 layer2 layer3)  and have block have 3 tags (tag1 tag 2 tag3) iwant every text within block border convert to its atrrribute( txt in layer1 to tag1.... txt in layer2 to tag2
Sea-Haven
I have to go so just did a quicky for a start ver2 would sort by layer so pick window for text. Will expand so not hard coded for 3 text.
; Pick 3 text update block atts
; By AlanH June 2021
(defun c:ver1 ( / x y )
(setq y 1)
(repeat 3
(setq txt (cdr (assoc 1 (entget (car (entsel  "\nPick text"))))))
(set (read (strcat "textlay" (rtos y 2 0))) txt)
(setq y (+ y 1))
(setq x 1)
(foreach att (vlax-invoke (vlax-ename->vla-object (car (entsel "\nPick block"))) 'getattributes)
             (vla-put-textstring att (eval (read (strcat "textlay" (rtos x 2 0)))))
			 (setq x (+ x 1))
(princ)
(ver1)
pbejse
Asked and answered so many times, what one more then.
(Defun c:T2A ( / tagAndLayersNames ss i lst e ll ur en tagN);; Text to Attribute
;;		pBe Jun 2021		;;;
;;	Tag and layer names  | change the values to suit your needs 	;;
(setq tagAndLayersNames
       '(( "TAG1" "LAYER1")( "TAG2" "LAYER2")( "TAG3" "LAYER3")))
  (if (setq ss (ssget '((0 . "INSERT")(66 . 1))))
    (repeat (setq i (sslength ss))
      (setq lst nil
	    e (vlax-ename->vla-object (ssname ss (setq i (1- i)))))
      (vla-GetBoundingBox e 'll 'ur)
      (setq pts (mapcar 'vlax-safearray->list (list ll ur)))
      	(if (setq TextObjects (ssget "_W" (Car pts)(cadr pts) '((0 . "TEXT"))))
		(progn
		  (repeat (sslength TextObjects)
		    (setq en (ssname TextObjects 0) ent  (entget en) )
		    (setq lst (cons (list
				      (strcase (cdr (assoc 8 ent)))
				      (cdr (assoc 1 ent)))
					   lst
		    (entdel en)
		    (ssdel en TextObjects)
		  (foreach itm (Vlax-invoke e 'GetAttributes)
		    (if (And
			  (setq f (assoc (vla-get-tagstring itm) tagAndLayersNames))
			  (setq tagN (assoc (cadr f) lst))
		      (vla-put-textstring itm (cadr tagN))))
    )(princ)
HTH
the_ameral
thank u
the_ameral
thank u .that is i want
