- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm trying to return the Text Insertion Point of a Text Entity in Model Space, but struggling to understand why the value returned by (vla-get-Insertionpoint textobj) returns a coordinate that's nowhere near to the text entity.
When I 'List' the Text I get its 'true' value....(X=29) but when I 'dump' or 'entget' the text I get an X Value of -675 I'm thinking there may be some sort of transformation going on here but unsure how to tackle this? anyone have any ideas what's causing this ?
TEXT Layer: "Text-Standard(E)"
Space: Model space
Color: 7 (white) Linetype: "BYLAYER"
Handle = e9e89
Style = "A25X25T 30"
Annotative: No
Typeface = Arial Narrow
center point, X= 29.6359 Y= 485.5176 Z= 0.0000
height 2.5000
text EL. -22.871
rotation angle 30
but when I 'dump' or 'entget' the entity I get this (X Value way off)..
Select object: ((-1 . <Entity name: 7ffffbe4a90>) (0 . "TEXT") (330 . <Entity
name: 7ffffb1d9f0>) (5 . "E9E89") (100 . "AcDbEntity") (67 . 0) (410 . "Model")
(8 . "Text-Standard(E)") (62 . 7) (100 . "AcDbText") (10 -682.689 49.66 0.0)
(40 . 2.5) (1 . "EL. -22.871") (50 . 0.523599) (41 . 1.2) (51 . 0.0) (7 .
"A25X25T 30") (71 . 0) (72 . 1) (11 -674.994 54.1028 0.0) (210 0.0 0.0 1.0)
(100 . "AcDbText") (73 . 0))
Select object: ; IAcadText2: AutoCAD Text Interface
; Property values:
; Alignment = 1
; Application (RO) = #<VLA-OBJECT IAcadApplication 0000000140d27198>
; Backward = 0
; Document (RO) = #<VLA-OBJECT IAcadDocument 00000000271e2960>
; EntityTransparency = "ByLayer"
; Handle (RO) = "E9E89"
; HasExtensionDictionary (RO) = 0
; Height = 2.5
; Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 000000002a379418>
; InsertionPoint = (-682.689 49.66 0.0)
; Layer = "Text-Standard(E)"
; Linetype = "ByLayer"
; LinetypeScale = 1.0
; Lineweight = -1
; Material = "ByLayer"
; Normal = (0.0 0.0 1.0)
; ObjectID (RO) = 320
; ObjectID32 (RO) = 320
; ObjectName (RO) = "AcDbText"
; ObliqueAngle = 0.0
; OwnerID (RO) = 201
; OwnerID32 (RO) = 201
; PlotStyleName = "Color_7"
; Rotation = 0.523599
; ScaleFactor = 1.2
; StyleName = "A25X25T 30"
; TextAlignmentPoint = (-674.994 54.1028 0.0)
; TextGenerationFlag = 0
; TextString = "EL. -22.871"
; Thickness = 0.0
; TrueColor = #<VLA-OBJECT IAcadAcCmColor 000000002a283b70>
; UpsideDown = 0
; Visible = -1
; Methods supported:
There's a 700mm discrepancy in it's location
