Text height for mtext in AutoLISP
Hello, how can I define text size (height) in the following code?
(defun c:pdm (/ ins str)
  (and (or (> (getvar 'DWGTITLED) 0)
           (alert "Save the drawing then try again!")
       (setq ins (getpoint "\nChoose where you want to insert the file name : "))
       (setq str (entmakex (list '(0 . "MTEXT")
                                 '(100 . "AcDbEntity")
                                 '(100 . "AcDbMText")
                                 (cons 10 (trans ins 1 0))
                                 '(1 . "")
       (vla-put-textstring (vlax-ename->vla-object str)
			"{\\fArial|b1|i0|c0|p34;\\C2;%<\\AcVar Filename \\f \"%tc4%fn6\">%}"
  (princ)
Kent1Cooper
That's the DXF 40 entry.  If it's something that varies, and you have it asked for or calculated, and in a YourHeight variable:
  (cons 40 YourHeight)
  '(1 . "")
or, if not in a variable but as an always-known constant value:
  '(40 . YourHeight)
  '(1 . "")
YourHeight would be, or in the first case could be a variable containing, a real [decimal] number in drawing units.
Kent Cooper, AIA
ronjonp
Thread HERE too...
john.uhden
I've pretty much discovered, especially with annotative text, that it's better to use a text style with a fixed height of zero.  With fixed heights other than zero you end up stuck with the fixed height.  Yes, I think you can override mtext with formatting codes, but i don't like using them, personally.
John F. Uhden
