solid section , by its parts layer
subasio21
Message 1 of 10
subasio21
hello
when gettig a 3d solid section , can the generated region be  the same layer with its part?  is it possible to do this with  a lisp ?
Replies (9)
Message 2 of 10
hak_vz
Here is a section generated using 3 point method. You didn't specify how to create section so this is for a start.
(defun c:ssect ( / e eo lay p1 p2 p3 rego)
	(setq e (car (entsel "\nSelect 3d solid >")))
	(cond
		((and e)
			(setq eo (vlax-ename->vla-object e))
			(cond
				((= (vlax-get eo 'ObjectName) "AcDb3dSolid")
					(setq lay (vla-get-layer eo))
					(setq p1 (getpoint "\nFirst point of section plane >"))
					(setq p2 (getpoint "\nSecond point of section plane >"))
					(setq p3 (getpoint "\nThird point of section plane >"))
					(command "_.section" e "" p1 p2 p3)
					(setq rego (setq eo (vlax-ename->vla-object (entlast))))
					(vlax-put rego 'Layer lay)
(princ)
Miljenko Hatlak
Message 3 of 10
hak_vz
For multiple 3d solids at different layers cut by single cutting plane defined with 3 non collinear points
(defun c:ssectm ( / adoc ss e i eo lay p1 p2 p3 rego *error*)
	(defun *error* ( msg )
		(if (not (member msg '("Function cancelled" "quit / exit abort")))
			(princ (strcat "\nError: " msg))
		(if adoc (vla-endundomark adoc))
		(setvar 'cmdecho 1)
		(princ)
	(setq adoc (vla-get-activedocument (vlax-get-acad-object)))
	(vla-startundomark adoc)
	(setvar 'cmdecho 0)
	(princ "\nSelect 3d solids to cut >")
	(setq
		ss (ssget '((0 . "3DSOLID")))
		i -1
		e (entlast)
	(cond
		((and ss p1 p2 p3)
			(while (< (setq i (1+ i)) (sslength ss))
				(setq
					eo (vlax-ename->vla-object (ssname ss i))
				(command "_.section" (ssname ss i) "" p1 p2 p3)
				(while (setq e (entnext e))
					(setq rego (setq eo (vlax-ename->vla-object e)))
				(setq e (entlast))
	(setvar 'cmdecho 1)
	(princ "\nDone!")
	(princ)
Miljenko Hatlak
Message 4 of 10
subasio21
thanks a lot  this is great.
also can you add the height of parts?
Message 5 of 10
hak_vz
@subasio21 wrote:
thanks a lot  this is great.  also can you add the height of parts?
Height of part? Can you  explain in more details?
Miljenko Hatlak
Message 6 of 10
subasio21
hello , thanks again
3d solid parts has the hight ( thickness )
Message 7 of 10
hak_vz
3d solid parts has the height ( thickness )
I know, but how do I have to show it. Are you thinking about some kind of auto dimensioning?
I'll guess your section plane is always vertical.
Miljenko Hatlak
Message 8 of 10
subasio21
hello
it can be change the color of reigon,  I mean when the parts thicknees is 20 than generated region color can be 20. so I will know what is the thickness of part
Message 9 of 10
hak_vz
(defun c:ssectm ( / adoc ss e i eo lay p1 p2 p3 rego height *error*)
		(setvar 'cmdecho 1)
		(princ)
	(setvar 'cmdecho 0)
	(setq
		i -1
		e (entlast)
	(cond
		((and ss p1 p2 p3)
				(setq
					height (atoi (rtos(abs(* 2 (caddr (vlax-get eo 'Centroid)))) 2 0))
					(cond ((and (>= height 1)(<= height 255))(vlax-put rego 'Color height)))
				(setq e (entlast))
	(setvar 'cmdecho 1)
	(princ "\nDone!")
	(princ)
This will work only if extruded part height (thickness)  is an integer value in range 1 to 255
Miljenko Hatlak
Message 10 of 10
subasio21
thanks alot
best regards
