Text from selection to excel
Philip-John
Message 1 of 45
Philip-John
I have some texts (top and bottom) in my drawing as above. I just need to have these in excel.
After selection of the top texts (point 01 - 08) it should go in first column of excel file and after selection of bottom texts (23.65 - 22.10) it should go in second column of excel file.
Accepted solutions (4)
Replies (44)
Message 41 of 45
Travis.Biddle
Perfect, thank you so much for all your help!!!
Message 42 of 45
rajuksk_piping
1. Can this code be updated for selecting text or mtext also
2. while exporting text is seperating with column i dont to seperate the text
can anyone help me to update this lisp
Message 43 of 45
rajuksk_piping
I need some update in this lisp, can anyone help me
1. selection of text & mtext also
2. text or mtext while exporting to excel should be seperated by column
pls help me
Message 44 of 45
rajuksk_piping
(defun c:RTC ( / _sortsel _dxf fc csvfile opf row collection _comma ); Row to column
(defun _sortsel	(sel cl)
  (mapcar 'cdr
	  (vl-sort
	    (mapcar '(lambda (e)
		       (redraw e 3)
		       (list (_dxf 10 e) (_dxf 1 e) e) )
		    (vl-remove-if 'listp (mapcar 'cadr (ssnamex sel))) )
	    '(lambda (a b) (< (caar a) (caar b)))
(defun _Dxf (d e)(cdr (assoc d (entget e))))
(setq collection nil inc 0
      _comma (lambda (s)(strcat s ","))
(While
  (progn
      (princ (strcat "\nSelect text for column "
		     (itoa (setq inc (1+ inc))) " "
      (setq fc (ssget '((0 . "TEXT")))))
  (setq collection (Cons (_sortsel fc inc) collection))
(if  (setq collection (reverse collection))
  (progn
    	(setq csvfile (strcat (getvar 'dwgprefix)
			  (vl-filename-base (getvar 'dwgname)) ".csv"))
	(setq opf (open csvfile "w"))
	(while (and (Car collection)
		    (setq data (mapcar 'car collection))
	  (setq row (apply 'strcat (mapcar '_comma (mapcar 'car data))))
	  (write-line row opf)
	  (foreach itm (mapcar 'cadr data) (redraw itm 4))
	  (setq collection (mapcar 'cdr collection))
    	(close opf)
    	(startapp "explorer" csvfile)
  (princ)
Message 45 of 45
rajuksk_piping
Code is given above
