Text as layer to surrounded closed polygons
Message 1 of 11
Dear Helpers,
I need a lisp that should create layers from texts inside selected polygons and those layers to be applied to self surrounded polygons.
Please have a look on attached image and drawing for better understanding.
T.Brahmanandam
Accepted solutions (4)
Replies (10)
Message 2 of 11
pbejse
Hold on, you're going about this the wrong way tnvsb, you've been posting one request after another which I believe are somehow connected. I would suggest explaining your ultimate goal then request for one consolidated program.
As I've said it before, please post a realistic sample drawing to be tested on. AND show a BEFORE and AFTER scenario.
Message 3 of 11
Thank you Sir,
I have 500 different zones with unique zone names inside the polygons. But I need all polygons to be in their respective layers with their zone names Sir. So I can work with the polygons whatever I can do like listing the polygon for area, perimeter, Elevation and other data with DATA EXTRACTION TOOLS and so much etc...
Message 4 of 11
Kent1Cooper
We don't need any more of a drawing than you've already posted.  Try this [minimally tested]:
(defun C:PLLTI (/ plss n); = PolyLines to Layer of Text Inside
  (if (setq plss (ssget '((0 . "LWPOLYLINE"))))
    (repeat (setq n (sslength plss)); then
      (setq pl (ssname plss (setq n (1- n))))
      (if
        (setq txtss
          (ssget "_WP"
            (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget pl)))
            '((0 . "TEXT"))
        (command
          "_.layer" "_new" ; [won't matter if it already exists]
          (setq layname (cdr (assoc 1 (entget (ssname txtss 0)))))
          "_.chprop" pl "" "_layer" layname ""
  (princ)
That assumes User selection of Polylines, presumably with a big window or whatever.  It could be made to find the Polylines itself, and could filter for closed ones, and/or for 4-sided ones, etc.
Kent Cooper, AIA
Message 5 of 11
Thank you so much Sir, It is really appriciated from my end for your spontaneous and smart reply. It helps me more to reduce more time spending on draiwng.
Message 6 of 11
pbejse
We mere mortals need our B & C. 🙂
I hesitated to post this code as I was waiting for more info
FWIW, I had it similar with Kents post.
(Defun c:BTL (/ ss s ve pts)
  (if
    (setq ss (ssget '((0 . "LWPOLYLINE"))))
     (repeat (setq s (sslength ss))
       (setq ve (ssname ss (setq s (1- s))))
       (setq pts (mapcar 'cdr
			 (vl-remove-if-not
			   (setq ent (entget ve))
       (if (setq TextInsideBox (ssget "_WP" pts '((0 . "TEXT"))))
	 (entmod
	   (subst
	     (cons 8 (Cdr (assoc 1 (entget (ssname TextInsideBox 0)))))
	     (assoc 8 ent)
	     ent
  (princ)
HTH
Message 7 of 11
Working like a charm, fentastic thank you for your efforts.
Message 8 of 11
devitg
Hi , pbjse, please clear  me how do you cope with SSGET "WP" with no ZOOM to , at least, polyline bounding box??
Message 9 of 11
pbejse
Your confusing "W" with "WP" mode. "WP" works regardless if the object is visible on screen or not.
Message 10 of 11
devitg
Hi , thanks for it .
Message 11 of 11
-didier-
Coucou / Hello
You write
"Your confusing "W" with "WP" mode. "WP" works regardless if the object is visible on screen or not."
I'm not sure you're right
if the entities are not visible (zoom factor) they are ignored from the selection, at least on my pc
can you check please ?
amicalement / regards
Éternel débutant.. my site for learning : Programmer dans AutoCAD
DA
