TEST for you
TEST for you
john.uhden
Mentor Mentor
TEST for you
john.uhden
Tell me what's wrong with this function.  It gets used numerous times in a routine I am writing.
No, it's not that the @Anonymous function is missing.  Yes, I found the error this morning.
It is something for which we must always watch out.
Hint:  It caused the creation of 72-vertex polylines when they should have been 4-vertex.
  ;; Function to rotate a set of points (data) in the format
  ;; (pt pt pt ... ) about a base point (bp) from p1 to p2:
  (defun @rotdata (bp p1 p2 data / delta ang p newdata)
     (setq delta (@delta (angle bp p1)(angle bp p2))) ;; changed (08-07-18)
     (foreach p data
        (setq p (polar bp (+ (angle bp p) delta)(distance bp p))
             new (cons p new)
     (reverse new)
John F. Uhden
Kent1Cooper
The 'new' variable is not localized, so as the function "gets used numerous times," on subsequent uses 'new' keeps getting added to, instead of being limited to the result from the current 'data' list.  It would suffice to just change 'newdata ' in the localized variables list to 'new' as used in the function definition [or vice versa] -- as it is, 'newdata' doesn't exist in the routine.
[You also have a localized variable 'ang' that doesn't exist in the routine, but that wouldn't keep it from working right.]
Kent Cooper, AIA
Moshe-A
Hi John,
there are 2 unused local variables  ang  + newdata
new variable is global?
moshe
john.uhden
Excellent!
@Kent1Cooper and @Moshe-A have very sharp and experienced eyes.
Technically, Moshe gets an A, but Kent gets an A+.
John F. Uhden
ronjonp
FWIW I'd use mapcar for something like this then you don't need to reverse the result:
(defun @rotdata2 (bp p1 p2 data / delta delta)
  (setq delta (@delta (angle bp p1) (angle bp p2)))
  (mapcar '(lambda (x) (polar bp (+ (angle bp x) delta) (distance bp x))) data)
john.uhden
I have a bundle of old stuff that looks like kindergarten work. But at
least it works.
Thanks!
John F. Uhden
