Temporary Disable all Xcliped Insert and nested Insert
xinxirong
xinxirong
I can't purge some layer,so i close all the other layers,nothing showed.
I had found it was the xcliped Insert hide it .
Is it possible to Temporary Disable Xclip?
cadffm
If you made an mistake (used an object as clip frame with an Layer what shouldn't used for it)
you can use QSELECT,FILTER,SSX or something like that to
select all objects with LayerXY, then change the layer to Layer0 for xclip-cut objects
Sebastian
